Next Blu Ray upgrade?
28 replies [Last post]
atkins4725
atkins4725's picture
Evening all,
The time has come to replace my CA 650bd. Players I'm looking at are the CA 751 or a Marantz unit to match my SR 7005. I'm not a massive techno guru and I'm struggling to workout wich Marantz unit would be an all round upgrade and not just a side step.
The CA I can take home and audition but the Marantz I can't!! Should the UD7006 provide a noticeable upgrade with both music and movies over my 650bd???
__________________
Philips 56PFL9954H, Sky HD, Marantz SR 7005, CA 751bd, Monitor audio Apex, Chord Prodac, Chord active HDMI's, Chord chorus 2, Chord odyssey 2, Atacama equinox rack.
bigboss
bigboss's picture
RE: Next Blu Ray upgrade?
If you let your receiver decode audio, you shouldn't notice any improvement. If you let your player decode audio, the difference will be very small. Only you can decide if that tiny difference is worth the upgrade, especially if your current player is working perfectly.
__________________
atkins4725
The player is always set to bitstream with movies so the player does the decoding. The analogue outs are used with chord chorus 2 interconnects when cd's are playing.
Surely, the difference with between the 650 & 751 should be very noticeable, should it not???
__________________
bigboss
bigboss's picture
Only you can decide that with an audition. Report back! Smile
__________________
DandyCobalt
DandyCobalt's picture
I did a 1 hour comparative test at richer Maidstone when the 751 came out. Vs a 650. The 751 won hands down in terms of sound and image, and is better than my Cyrus prexpdqx and pioneer lx53 for dacs.  I posted on this site somewhere.  The  transport is better too.  Go for it.
Ah, here it is...
http://www.whathifi.com/forum/home-cinema/cambridge-audio-bd751-vs-bd650...
__________________
Main: Pioneer tv + LX85, Sony HW15 Proj, Cyrus DAC XP+/Mono X300/CDXTSE2/PSXRx2, B&W CM8/CM1/PV1D, CA BD751, Virgin TiVo, Inspire Rega t/t, Benz Glider MC, EAR 834P phono amp; Slee Novo Headphone Amp
Second: Panasonic 42" E6B LED, Pioneer VSX-D2011, Kef eggs, Virgin TiVo
Chewy
Chewy's picture
If the player is set to bitstream, the amp is doing the decoding, not the player. In which case changing the player for a change in sound quality should (in theory) have little to no impact.
If you are using an analogue connection for CD's there may be a difference in CD playback quality.
What BigBoss said!
__________________
JVC X70 | Beamax 105" M-Tensioned Screen | Aerial Acoustics LR5's, CC5 and 4 x SR3's (7.2) | 2 x Paradigm Signature Sub 1's | Datasat RS20i | 3 x AB Systems 11000SE Monobloc amps + 6500SE 6-Channel amp | Oppo BDP-95 | NAD M50 | 24TB Synology 2413+| Netgear NeoTV 550 | PS3 | Darbee DVP5000 | Sonos Multi-room system
bigboss
bigboss's picture
Oh yeah, didn't notice that bit in OP's post!
__________________
atkins4725
Cause it is, my mistake Laughing out loud
Well, my 650 is on its way out. Sometimes doesnt load blu rays at all, have to keep turning off the machine and then reloading the disc, software is up to date so it isn't that. I didn' really want multiple boxes hence the universal player
__________________
bigboss
bigboss's picture
Ok, in that case, look at the upcoming Oppo 105 (apart from your shortlist). It's got some extremely useful features not found in any other blu ray player in the market.
http://hometheater.about.com/b/2012/09/19/oppo-formally-announces-bdp-10...
It should be launched this year.
__________________
strapped for cash
strapped for cash's picture
That's worrying. The 650 is hardly a cheap player and should last considerably longer. I know we live in a culture where everything seems immediately disposable, but if I bought a mid-to-high-end BDP I'd expect it to remain fully functioning for more than a couple of years! Such an experience would put me off buying another BDP from the same manufacturer.
bigboss
bigboss's picture
Agreed. My Panasonic BD60 still works flawlessly after more than 3 years of regular use.
__________________
gel
gel's picture
Lots of refurbished 650's on eBay.  Smile  My Pioneer still works great!
__________________
Panasonic 50GT50, Pioneer Bdp-lx71, Pioneer Vsx-lx70, B&W FPM Series & B&W PV1.
woodster
woodster's picture
My pioneer is good still and I absolutely do not need 3D, which will in my opinion is still a pain with those awful specs. It would have to be something spetacular to tempt me to upgrade for a while yet.
__________________
System1-Roksan Kandy L3 amp, Audiolab 8200 CD, B&W CM8's, Sonos zp90, Appletv  for spotify via macbook pro. Russ Andrews Classic PowerKord on Roksan & Audiolab.
System2-Marantz cd603, airplay via mac, Sonos zp90, Q Acoustics 2010
Home cinema-Pioneer vsx2020, virgin tivo, Boxee, pioneer bluray, humax hdsat pvr, kef3005 speakers, wdtv live, lg590 50 TV
Games room- pana 42" tv, ps3, sony reciever, humax freeview box, ma speakers, Sonos zp90
Master bedroom- Sonos zp120, Cyrus CD8 SE, Linn Kelidh speakers, Pioneer 26" tv, Panasonic bluray, virgin tv box. All rooms fed 30 mb broadband via homeplugs
atkins4725
Think im just gunna wait till the 650 pops its cloggs and buy a dedicated player and not go the universal route. Only thing now is i need to try and workout how much £££ to spend on a dedicated cd player without going over board taking in to account i'll be using the apex system for music aswell as movies.
My original buget was around £800 for the universal player but would this buy a cd player thats over the top for the apex???
I was considering the marantz pearl lite
__________________
bigboss
bigboss's picture
Why don't you buy a DAC
Why don't you buy a DAC instead?
__________________
atkins4725
RE: Why don't you buy a DAC
i've considered this and was looking at the Audiolab DAC. The only problems for me is that it adds yet another box. If the Audiolab DAC is considerably better than that of the Marantz pearl light (which has additional digital inputs) then I'll add It to my short list for a listen.
I'm gunna have a read up anyway but do you know if the Audiolab DAC is any different to that which is in the 8200cd ???
__________________
