14 posts / 0 new
Last post
rocketrazor's picture
Last seen: 1 week 15 hours ago
Multi region blu ray player
Thinking of getting a multi region blu ray player that will play all region blu rays as well as DVDs, but I can only find this website online that is uk based
http://www.mrmdvd.com/catalog/index.php?cPath=159
Can any one suggest a different website? Might buy a cheap one from the use and pay the import tax?
ta
bigboss's picture
Last seen: 3 days 12 hours ago
RE: Multi region blu ray player
What's wrong with mrmdvd? You get UK warranty as well.
Nothing's wrong, it's just a little expensive.
From richersounds I can get the Sony s5200 for £100, £110 with DVD multi region, but at mrdvd for multi region blu ray it's £250. £150 more expensive. Just wondered about being able to get it cheaper
cheers
gel
gel's picture
Last seen: 1 day 19 hours ago
cheers
If you phone up and say its much cheaper at another shop, they do knock money off.  Worth a try.
Stop
Didn't know that, cheers gel
gel
gel's picture
They knocked money off for me.   ;). £20.   Ask for more though.
Stop
bigboss's picture
cheers
To make a player multiregion for DVDs, all they need to do is enter a software code. But to make the player multizone for blu rays, it needs a hardware modification and so will be significantly more expensive. Given the price difference, you have to question the need for it. Most blu rays are region free in any case, or are available in zone B format.
gel
gel's picture
cheers
Yep, tell them how much cheaper they are elsewhere and they should be able to do something.
Stop
I'll have to give it some thought.
my main reason is that the WWE blurays are cheaper from the US sometimes by £10 -£15 and there not compatible with my PS3  :cry:
cheers for the info though guys
wolf7howl's picture
Last seen: 2 years 6 months ago
I ordered a multi region 6200 from Richer Sounds. It was only priced £10 more than the local region item, so they didn't bother with the premium.  It pays to build up a relationship with the dealers - not just in terms of money, the advice and open discussion is worth the effort.
Panasonic TX55AS802B, Sony STR-DN1040, Sony BDP-S6200, V HD box, Dali 1 5.1, Audioquest FLX SLiP speaker cable, Audioquest Pearl HDMI, Atlas Element Integra subwoofer cable, Cambridge optical and coax digital interconnects
bigboss's picture
As explained, multiregion for DVDs only costs £10 or so. Multiregion for blu rays is a lot more expensive as it requires a hardware mod. The players at Richer Sounds is multiregion for DVDs only.
dope's picture
Last seen: 2 years 3 months ago
Multi-region Blu-ray Mod Service
www.dvdchips.co.uk are now offering a modification service to add Blu-ray and DVD Multi-region to your existing BD player.
You have to send the player to them and pay £100 for the upgrade but that includes return carriage.
It may work out cheaper to buy the player from Richer Sounds or elsewhere and have it modded by DVD chips rather than buy from www.mrmdvd.com depending on the model.
Chrismas Albert's picture
Last seen: 2 years 1 month ago
Cheaper multi-Region Blu ray player
I own a Mac Blu rya player which support all regions but it only takes ne $39.95, And i am very satisfied abou it. If you ned, I can recommend to you.
Josepher's picture
player
for your information, mac go mac blu-ray player is my choice.
Log in to post comments
