looking for advice
hi there im not sure about what would got well with my yamaha rxa 2010. id like to stop useing my ps3 as my only blu ray. any ideas on what to look for and what to avoid.
thanks
thnks just so many out their
What's your budget, & what are your requirements? Are you going to listen to music as well? Do you want DVD-Audio / SACD capability as well? How many DVDs are you going to watch?
okay well music is not on the must list price could be upto 800 on it and it must be a better quality than my ps3 can give atm. lately i am gettin into films alot more
And what about DVDs? Do you have a lot of DVDs?
Don't expect a massive difference from PS3 when playing blu rays. For blu ray picture playback, I did not find any difference between my Panasonic BD60, PS3 & Denon 2500BT. The main difference is in DVD upscaling.
Your Yamaha will decode audio brilliantly, so you don't have to worry about sonic performance.
Look at Denon 1713UD, Oppo 93, Denon 2012UD, Marantz UD5007, Cambridge Audio BD651, Panasonic BDT500, Pioneer LX55 & Sony S790.
thnaks for replying. well tbh in trying to upgrade to blu ray but if it wont change much from the ps3 then should i really get one ?
- Login to post comments
Look out for traffic and avoid big lorries.
Sony and Panasonic seem favourites. Sony play SACD's where many do not. Best advice for bdp to start with reviews.
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
Base trap Project - http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
