How good is the Panasonic DMP-BDT220 as an audio CD player?
12 replies [Last post]
Metanoia
Metanoia's picture
Hi WhatHiFi
I am looking to buy a total new system. I am pretty much set on 2 B&W685's and a Marantz PM6004. Unfortunately I do not have the space for both a dedicated audio CD player AND a blu ray player. I read in the review on this site that the Panasonic DMP-BDT220 has pretty good audio quality. So now I am wondering: could I use it to play my audio CDs? I am sure that buying a CD6004 will give me better quality, but will the difference be huge? I have heard that speakers are most important and after that the amplifier. The CD player, I am told, is the least important link.
Or is there a blu-ray player out there with even better 2 channel audio CD performance?
Any other advice? Thanks!
Oldenbroke
Oldenbroke's picture
RE: How good is the Panasonic DMP-BDT220 as an audio CD player?
I am currently using the BDT220 as music source and it is
quite good. Haven't heard the CD6004 so can't compare.
If possible I would get the CD player. I find the 220 to be
a bit forward and gets tiring after a while. Had a lot of problems
using it to stream as well.
__________________
Sony KDL-40W2000; Onkyo TXSR-875; Q-Acoustics 2010i / 2000 +  bipolar rears; Panny BDT220; Sky HD box.
Rega RP3 Elys 2 + TTPSU / Rega Brio-r / Rega RS3
Metanoia
Metanoia's picture
Hi Oldenbroke, thanks for the reply. I am a bit confused though. You say it is quite good, but also gets tiring after a while. I am new to all the HiFi terms. What does "forward" mean? Can you please elaborate on your problems with streaming as well? My choice for the Pana 220 was based on the fact that it has DLNA in addition to good DVD upscaling and blu ray capabilities. Maybe I shouldn´t focus on the Pana?
Can anyone else reccomend a blu ray player that has:
Good blu ray visuals
Very good DVD upscaling
Fantastic CD audio sound (2 channel)
Easy to use and well functioning streaming from a networked hard disk
My space is limited but I have a bit of budget for the player. I could spend about 500 pounds on it.
ISAC69
ISAC69's picture
Metanoia wrote:
Hi WhatHiFi
a dedicated CD will be a better option for hearing music (anless you are going to buy a high end BD such as the OPPO 95 Exclamation Mark  )
I think it is better to buy a good CD for music such as the 6004 CD and a budget BD for movies  puzzled
__________________
Hi Fi : ROKSAN KANDY K2 - PROAC STUDIO 140 MK2  - ROTEL RCD1520 -  interconnects : Tellurium Q Black - Chord Chorus2
AV : YAMAHA RXV767 - WHARFEDALE 9.CM [C] / 10.2 [SR] / INFINITY PRIMUS PS8 [SUB]
bigboss
bigboss's picture
I would suggest you demo both options & compare. Panasonic has paid attention & added high quality DACs in some of its players:
http://www.whathifi.com/news/ces-2012-panasonic-blu-ray-players-feature-...
You can always add an external DAC to your blu ray player to improve audio performance.
__________________
lapuzrg
lapuzrg's picture
bigboss wrote:
I would suggest you demo both options & compare. Panasonic has paid attention & added high quality DACs in some of its players: http://www.whathifi.com/news/ces-2012-panasonic-blu-ray-players-feature-... You can always add an external DAC to your blu ray player to improve audio performance.
Hi Big Boss, will an external DAC (Any suggestion) improve the audio performance of my Sony BDPS-370? If yes, how do I connect it?
Your advise is much appreciated.
Thanks & regards, Smile
__________________
Hi-Fi : Marantz NR-1402 - Polk Audio TSi-300
Eye-Fi : Sony BDP-S370 - Sony LED TV 32EX52 - Run through my Hi-Fi
Rick1979
Rick1979's picture
I find cheap blu ray players to be very clunky and slow as cd player tbh. Sound wise the Sony 480 was'nt too shabby but still bettered by a cdp. If network streaming isn't needed something like azur 650bd, marantz ud5005 or Denon 1611 can be had for under £200. I owned the 650bd, it was awesome on 2 channel blu ray and worked just aswell as a cdp although my mates arcam cd62 beat it. Blu rays did look a little grainy too, not as good as the Sony 480.
I did buy a pioneer bdp320 for £60. Awesome for that money, upscales DVD brilliantly well and excellent with blu ray and cd wise sounds the same as my azur 650cd player except the voices are further in the background whereas the voices on the azur are right in your face.
I tried to be happy with one box but wasn't. I paid £150 for the azur and £60 for the pioneer and now very happy. If you need Netflix, iplayer and YouTube I can highly recommend wdtv live. It's awesome and pq is as good if not better than sky hd.
Ive had an rdac, vdac ii and it barely bettered my Sony 480 and tv Dac. I was so disappointed i sold both and bought separate boxes.
Ben K.
Ben K.'s picture
I have a pioneer bdp320 and until recently a marantz cd6003. The cd6003 is better for cd sound quality by quite a bit IMO. The way I would explain it is: listening to cd on the pioneer music sounds ok but switch to the marantz and it sounds as if a box has been lifted off each speaker, much more open and natural.
__________________
AV: Sony KDL37w5500-Yamaha RXV2065-Monitor Audio RX8 AV12-Pioneer BDP320-Chord & QED cables and connects-------------
HI-FI: Arcam A38-Arcam CD37-Monitor Audio RX8-Chord cables and connects
lapuzrg
lapuzrg's picture
Thanks for your thoughts, Rick Smile
__________________
lapuzrg
lapuzrg's picture
Hi Ben your inputs are much appreciated. I'm here in the Middle East at the moment, and I saw a Marantz CD6003 but unfortunately, the salesman won't allow me to listen to it. Angry Based on your description, the sound is open and natural. So, would you give me the green light to go and buy it for SR 1,300 (Saudi Riyal) even without hearing it? FYI, I'm using a Marantz NR-1402.
__________________
Ben K.
Ben K.'s picture
When I compared my blu ray to my CD player both were connected to my Yamaha rxv2065. Blu ray via hdmi and cd via analogue interconnects. For me the cd was superior for cd play back.
I have not heard your av receiver or the Panasonic blu ray so can't advise directly. A friend of mine has a Panasonic dmp-bdt320 and it is a very good blu ray player although I doubt it would stand up against the marantz CD player for cd play back.
If your marantz has digital inputs and the Panasonic your looking at has a digital output the two together connected digitally may be a good compromise if you only want one box. That way you will use the dac in your marantz and the Panasonic as a transport.
Sorry I would not like to tell you what to spend your money on as your tastes and interpretations may be very different to mine.
I can tell you that the cd6003 is a very good CD player for the money it costs here. Sorry I'm not familiar with your currency.
__________________
lapuzrg
lapuzrg's picture
Ben, really appreciate your thoughts. I am leaning on getting the Marantz CD-6003 to team up with my Marantz NR-1402 a/v receiver. Hopefully, they match & will have a good synergy
Have a nice day Smile
__________________
JimyAdam
JimyAdam's picture
Your suggestion is good but i want to give you my opinion is that Samsung 5.1 Channel 1330W 3D Blu-ray Home Theater System Enjoy a more realistic experience with Vacuum Tube and Digital Sound. Hear your favorite music for the first time with the innovation of analog and digital sound combined.you fined this on http://www.hookprice.com/pd/samsung-ht-e6730w-7-1-3d-home-theater-system... with deals and coupons for your saving discounts.
