help,problem choosing blu ray player
9 replies [Last post]
jason6
jason6's picture
Hi,I hope someone can assist,I have an onkyo 609 and don't know what blu ray to partner with it,I'm currently using my ps3.I want a universal player as I have over 500 cds and listen to a lot of music also have 70 blu raysi was looking at the marantz 7006 or the denon 2012 or maybe the pioneer bdp lx55.can someone please help,I obviously listen to more music and then blu ray but want both to sound good.
jason6
jason6's picture
speakers
I have polk audio rti8 floorstanders,rti4 bookshelves,ma rw12 sub,polk audio centre
Samsung 40 inch lcd but am looking to upgrade to panasonic th p50vt30 soon.
professorhat
professorhat's picture
RE: help,problem choosing blu ray player
When you say you want a Universal player, are you looking for one which will play the likes of DVD-A / SACDs, or are you just looking for a player that will play Blu-rays and standard CDs?
lxd55
lxd55's picture
Hi Jason6,
Can definately recommend marantz ud7006. See my post (ps3 upgrade):
http://www.whathifi.com/forum/blu-ray-players/marantz-ud7006-versus-ps3
April version of what hi-fi had group test on blu ray players. It had the the Denon DBP-2012UD as the group winner but this appears to be due to it being typically £50 cheaper than the Marantz and both being virtually the same electronics. It states that musically (cd) the ud7006 is slightly better, which based on your requirements might be the better choice??
__________________
Sony KDL-46NX713, Sony STR-DA5400ES, Marantz UD7006, Marantz NA7004 NAP, 4TB Linkstation Duo, Humax Foxsat-HDR,Wireless Buttkicker, B&W 684 front's bi-amped Chord Odyssey 4-4, B&W HTM62 Centre, B&W M1 rear's, MJ Acoustics Pro 50 MK II Sub, Atacama Equinox AV stands, Zeppelin Air, Ipad2, ATV3
jason6
jason6's picture
hi lxd55
Thanks for the reply,I was leaning towards the marantz 7006,its a bit pricier than the denon 2012 but seen that I have a vast cd collection it does make sense to go that route just wonder if they will sound ok with my polk audio's as it is very difficult for me to get a demo where I live therefore I will. Be buying in the dark.wish me luck.
jason6
jason6's picture
hi professorhat
I was looking for playback on blu ray,dvd and standard cd's
bigboss
bigboss's picture
Online
RE: hi professorhat
All blu ray players playback blu rays, DVDs & CDs. You don't necessarily need a universal player. Also remember that the Denon 2012 & Marantz UD7006 are same players in different chassis.
The Marantz being "slightly better" for audio only means that you won't notice any difference during casual listening, & even during a careful side by side demo, you have to concentrate really hard to notice the difference. Only you can decide if this sort of difference is worth the extra outlay.
__________________
toyota man
toyota man's picture
 Hi you can buy the denon for less than £500 now I have one which I use for casual listening and it sounds very good fantastic with dvds and blue rays good luck in your search:)
__________________
jason6
jason6's picture
Thanx a lot guys,gonna make
Thanx a lot guys,gonna make my choice and take the plunge.
jason6
jason6's picture
