Help with sony bdp s300
3 replies [Last post]
gazman3510
gazman3510's picture
Hi I have a Sony BDP s300 bluray player and a ONKYO TXNR609 receiver I know this is an older blu ray player but what surround formats can I use as I don't know if I can use Dolby TRUE HD also what is the best way to set it up with the ONKYO
Many thank Gaz
bigboss
bigboss's picture
RE: Help with sony bdp s300
If you've updated your player's firmware, it will decode Dolby True HD:
http://www.engadget.com/2008/09/02/bdp-s300-firmware-4-20-adds-dolby-tru...
Even if not, you can always bitstream audio for your Onkyo receiver to decode it in the true format.
You just have to connect your Sony to your Onkyo with an HDMI cable. The Onkyo then connects to your TV with another HDMI cable.
__________________
gazman3510
Thanks BIGBOSS What output settings do I have to select on the blu ray player PCM /bitstream
bigboss
bigboss's picture
PCM will make your Sony decode audio, while bitstream will let your Onkyo do the job.
__________________
