help with replacing my blu ray player
16 replies [Last post]
gar1975
gar1975's picture
hi....  i am currently using a pioneer bdp lx71 which has refused to play a couple of discs (player has been updated)  so i have decided to buy a new player,  but i have no idea what player would be a good replacement,  the picture and sound from the 71 is great so will want something to at least match that.  not overly bothered if it has wifi or a good range of web based stuff,  youtube etc...
any help/advice in choosing a new player would be really appreciated
thanks in advance...
bigboss
bigboss's picture
Online
RE: help with replacing my blu ray player
What's your budget, & what's the rest of your system like?
__________________
gar1975
gar1975's picture
under £1000... sorry i thought my system showed up on my listings... i have a pioneer pdp lx 6090 plasma & a yamaha z11  not interested in 3d
DandyCobalt
DandyCobalt's picture
Cambridge Audio BD751 is a good place to start looking. Great sound/image (very good upscaling) and hasn't rejected any of my discs yet (CD, BD, DVD, DVD-A, SACD).
__________________
Main: Pioneer tv + LX85, Sony HW15 Proj, Cyrus DAC XP+/Mono X300/CDXTSE2/PSXRx2, B&W CM8/CM1/PV1D, CA BD751, Virgin TiVo, Inspire Rega t/t, Benz Glider MC, EAR 834P phono amp; Slee Novo Headphone Amp
Second: Panasonic 42" E6B LED, Pioneer VSX-D2011, Kef eggs, Virgin TiVo
bigboss
bigboss's picture
Online
For superior audio, look at Cambridge Audio BD751, Oppo 95, Marantz UD7006 & Denon 2012.
__________________
John Duncan
John Duncan's picture
Online
+1 for the Cambridge, though it's the only top end player I know - Bigboss's alternatives would do just as well, undoubtedly.
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
psurquhart
psurquhart's picture
Hey Big Boss,
I know your always good for advice and I know you know your stuff.
But was wondering why you only purchased the Panasonic BD60 ? Nothing wrong with it of course, a fine player but quite a basic mid range machine. Was wondering why you have not gone for the usual hit list above and if you did what one would you go for ?
I have always fancied the Denon for an all over, do it all player.
Interested in your thoughts.
__________________
bigboss
bigboss's picture
Online
psurquhart wrote:
Hey Big Boss,
Basically I was interested in blu ray picture quality only. My Yamaha decodes audio & my Pioneer Kuro upscales DVDs which I'm happy with. So I wasn't interested in audio performance or DVD upscaling. Between different blu ray players, that's where the main difference lies.
For blu ray picture playback, I did not find any difference between my Panasonic BD60, PS3 & Denon 2500BT, so I found no reason to spend more on a blu ray player.  Smile
__________________
bigboss
bigboss's picture
Online
I have a load of Video CDs which my Panasonic cannot play. My next player will likely be an Oppo which will play them. But increasingly, I'm thinking of going for a blu ray player with Google TV, like the Sony one coming this summer.
__________________
DandyCobalt
Big Boss's reply is very interesting, as I had a similar conversation with Jonathan when I was at the "Big Question" day at WHFSV.
In my case, the CA BD751 does a brilliant job of decoding audio and upscaling video - so I don't need these features in the a/v receiver.
A lot of the other features of the top a/v receivers (which obviously add to their cost) might already be well serviced by another piece of kit in the chain.
__________________
gar1975
gar1975's picture
thank you all for getting back to me...  i think i am going to have a look at the marantz ud7006 & the denon 2012 as i have seen them locally with a good discount.
but one last question... as i have a good tv & a good amp that will be handling the sound,  do i even need to go as high as either the marantz or the denon?  could i get away with a cheaper player like the new pioneer LX 55
BenLaw
BenLaw's picture
With your virtually reference level tv and amp, I don't see that you need a premium player, unless you need the additional multi- format capabilities.
__________________
HiFi   /   A/V   /   Bedroom
bigboss
bigboss's picture
Online
I agree with BenLaw. But you should demo the players yourself & decide. The LX55 is a brilliant player in itself.
Remember that the Marantz & Denon are basically the same players in different clothing. So if you want to decide between them, look at the cost & aesthetics.
__________________
WazP
WazP's picture
That might depend on how (and if) you have the need to play multichannel SACD and DVD-Audio discs.  The Oppo, Marantz, Denon and Cambridge Audio that bigboss mentioned all have 5.1 analogue outs from their players, and as your Yamaha has multi channel ins, you can either use these connections and have the blu-ray player doing the DAC work, or use the HDMI cable instead to transfer the audio digitally and let the Yamaha do the DAC work.
Crucially for multichannel SACD, both player and receiver need to output and input respectively DSD over the HDMI cable.  All the four players above do and your receiver also supports it.
The Pioneer BDP-LX55 doesn't have multi channel outs, so you have to use the HDMI cable for multichannel audio.  Again this supports DSD without issues.
Dan Turner
Dan Turner's picture
Really recommend the Cambridge Audio 751BD. The picture and sound quality are outstanding.  Also plays a wide range of streamed video content without fuss.
__________________
Sonos ZP90 / CA 751BD / Sky HD / Apple TV
-> AVI ADM40
-> Panasonic PDP50G10
gar1975
gar1975's picture
again,  thanks for your input guys...
not interested in sacd or dvd-a.
i am going to demo the denon marantz & the pioneer,  have excluded the cambridge audio as i cant find it for much less than rrp  i have seen the denon for £479 &  the marantz at a similar price & am sure i could get some £ knocked off the pioneer at my usual retailer =)
am looking forward to seeing if i can spot any differences with my current player!  =)
