6 posts / 0 new
Last post
rafeeq's picture
HDMI to Yellow RCA video cable or converter
I have Pioneer Blu-Ray Player BDP-160 (which has HDMI connection to connect to TV) but unfortunately my old TV has no HDMI input and only has video input (Yellow RCA Jack). Now I need expert openion in order to view blu ray movies whetherI may connect a HDMI to RCA Analogue video cable or I may require HDMI to RCA converter. Please suggest how I can watch blu-ray movies.
MajorFubar's picture
Last seen: 1 day 2 hours ago
RE: HDMI to Yellow RCA video cable or converter
You'll need some kind of powered converter of some sort. HDMI is a digital interface and is completely incompatible with the (analogue) stereo audio and composite-video sockets on the back of your TV. It's not just a case of the same wires soldered to a different shape of plug. However I'd imagine eBay has quite a few options if you have a look.
Audio: MacMini / AEX > AVI DM10 + BK Gemini II sub; Visual: Samsung BD-C5500 > Panasonic TX-L47ET5B.
Head-fi: various, but most often Sennheiser HD-580 or RS-180
daveh75's picture
Last seen: 4 hours 34 min ago
Time to buy a new TV.
Theres absolutely no point to BD if converting to composite video ( the absolute worst video quality)
spiny norman's picture
Last seen: 5 days 8 hours ago
Agreed with daveh75, but if you need a temporary measure, something like this would do the job. However, bear in mind that your TV's going to need stereo analogue audio ins as well as the composite video in to work with a box like that.
And given that the box is going to cost you £50+, I'd be putting the money towards a new TV, as daveh75 said.
And so, on Feb 22nd 1966,...
iMark's picture
Last seen: 4 days 19 hours ago
If the TV doesn't have stereo in, you could always use an RCA to scart adapter, something like this:
http://www.amazon.co.uk/Scart-Adaptor-Phono-Sockets-Audio/dp/B000L1LY58/ref=pd_cp_ce_0
Pro-Ject 1Xperience Comfort (OM 2Red), Yahama R-N602, Sony UHP-H1, Sony TV, Humax DVR, Infinity Overture 1 speakers. Range from very cheap to expensive cables.
Yes, that would be an option. Still think the OP should be putting the money toward a new TV, though.
Log in to post comments
