Dual HDMI or Another way of connecting to an older Receiver?
3 replies [Last post]
Franklioni
Franklioni's picture
Hi All...
The kids DVD player has taken a tumble so I'm thinking of putting our current bluray player (Panasonic DMP-BD30) upstairs and buying a new 3D one for down but so bothered about wifi as the dongle in the TV covers that pretty well.
The new player would be connecting directly to the TV for picture but still to my Denon AVR-2307 for sound so I'm not sure if I should go for something like the Panasonic DMP-BT310 and do the HDMI connection or the cheaper 110 and do something like optical...any ideas?
Thanks in advance...
Franklioni
__________________
Denon AVR-2307, Cambridge Azur 640C V2, B&W 685 (F), Mordaunt-Short Premiere 304C, B&W AS1, QED Silver Anniversary XT (BW), QED Quinex 3 interconnects, Panasonic DMP-BD30, Samsung UE46C8705 LED and some really EDITED Panasonic rear speakers that are still holding their own...only just!
markjaspi
markjaspi's picture
RE: Dual HDMI or Another way of connecting to an older Receiver?
If you go for the 110 and use the optical connection you will not get HD Audio on 3D Blu ray, only the core DTS/Dolby 5.1. Also you would have to change the settings each time in the menu to get it to decode and bitstream the HD sound track on standard Blu rays, via HDMI. (each time you swap between the two) For the hassle I would spend the extra on the 310.
__________________
Panasonic 50GT30B | Marantz SR5006 | Boston Acoustics A26 front - A225C - A26 rear | Panasonic BDT310 | Sky+ 1TB HD | Virgin TiVo | iPad 2 | Samsung Galaxy SIII | New Apple TV | Control: Roomie via iPad & iPhone | Xbox360
micks_address
micks_address's picture
you could also look at a player with analogue outs that transcodes the HD codecs to PCM.. that way you'd still get lossless audio to the AVR
__________________
Panasonic 42VT30 Plasma, Denon AVR 3310, Opp BD93, MA Radius 225HD left/centre/right, MA Radius 90HD surrounds, RSw12 sub, Harmony 1100 remote, Project RPM5 Turntable
Franklioni
Thanks very much!
__________________
