113 posts / 0 new
Last post
altruistic.lemon's picture
Last seen: 2 years 2 months ago
Do all Blu-ray players output the same quality sound and vision?
This came up in another thread and thought it deserved a thread of its own.
WHF certainly don't think so if you read the reviews - hope this link displays properly, it looks fine in the edit but a bit weird in view -  http://www.whathifi.com/reviews/home-cinema/blu-ray-players but many in the forum think there's no difference.
Opinions?
manicm's picture
Last seen: 5 days 20 hours ago
RE: Me thinks not...
Some here in the WHF forums believe so, but if they're basing it on 'scientific' fact, they're wrong.
Most premium players include the ubiquitous Marvel ODEO video chipset which includes the video DAC. Some like the Marantz/Denon include the Anchor-Bay chipset. It boils down to this: do you believe all audio DAC chips sound the same? Note Wolfson, for example, have a range of DACs.
So are all DAC chips, video or audio, the same? NO. Can they sound/look different? YES.
Will the user notice? POSSIBLY.
BenLaw's picture
Last seen: 1 year 12 months ago
In what way does a blu ray
In what way does a blu ray player convert video to analogue? Think HDMI...
I am the danger.
gel
gel's picture
Last seen: 2 days 20 hours ago
Some do and some don't.
Some do and some don't.   Smile
Stop
BenLaw's picture
RE: Some do and some don't.
They really don't.
I am the danger.
mr malarky's picture
Last seen: 2 years 8 months ago
Be interested to see a reply from WHF on this question?
BIGBERNARDBRESSLAW's picture
Last seen: 9 months 1 day ago
RE: sound and vision on Blu Ray players?
I think they are more or less the same. Some may upscale dvds better, some have more and varied connections, some are better made than others, some load quicker than others, but if you are just watching blu rays, the SQ and PQ is the same IMHO.
Panasonic TX-P50GT50 / Yamaha RX-A2020 / Panasonic DMP-BDT110 / Dali Zensor 3 / Dali Zensor Vokal / Mordaunt Short MS20i Pearl Edition / Cambridge Audio Minx 11 / Tannoy TS2.10 / Roksan Radius 5.2 / Ortofon Super OM 20
strapped for cash's picture
Last seen: 5 months 2 weeks ago
Yes, different BDPs use different processing chips, but as Ben says, no digital to analogue conversion takes place with video output over HDMI.
Marvell and Anchor Bay chips upscale lower resolution sources, but again no digital to analogue conversion takes place. Audio DACs and video processing chips do very different things.
There's some debate over whether certain higher-end BDPs add processing to 1080p content give images extra pop (undefeatable contrast or colour boosting, for example, or artificial sharpening). If so, viewers might think the resulting images look subjectively better.
BenLaw's picture
Which are said to and which are not?
I am the danger.
I think EllisDJ is better placed to advise on this. I've read something about the Denon DVD2500BT boosting colour (and perhaps contrast). I can't recall the specifics.*
I used to own this player, though I was using it with an uncalibrated Panasonic V20. Based on my experiences, I wouldn't be shocked to discover that some boosting was taking place.
Colour variations could be tested objectively with a reliable meter. (With each BDP running the same Rec.709 test patterns via disc or USB.)
Testing for variations of contrast should be easier. You could play greyscale ramps to check whether blacks crush and whites clip before they should. (A television's native contrast obviously won't change. If a BDP is boosting contrast to a notable degree this would manifest as crushing and clipping.)
* This sounds like a dodge. Hopefully EllisDJ can provide links to information on this subject. I think he did so a few months back.
gel
gel's picture
I pretty much went through
I pretty much went through the entire new group of expensive Blu-ray players and all were the same, I have owned a cheap Sony Blu-ray player and a Playstation 3 but they didn't measure up to the expensive ones for me.  I don't think you have to spend any more money than the Oppo 103 for sure.
Stop
professorhat's picture
Last seen: 2 months 2 days ago
RE: Do all Blu-ray players output the same quality sound
I definitely perceived differences when I did some side by side comparisons with my older player before I purchased my Marantz. Was it all in my head? Well yes, that's where my brain is...
But no, I didn't ABX test them, so feel free to listen to or ignore me as you feel fit.
The owls are not what they seem...
carter's picture
Last seen: 1 year 2 months ago
RE: Do all Blu-ray players output the same quality sound and vis
I find it hard to believe there is no difference between hi end and entry level players but I must admit I'm happy with what I've got and don't feel the need to spend a lot of money for daminishing returns.
Would like to see a side by side,budget bluray player,cheapo hdmi,standerd power cables next to a high end bluray with all the fancy hdmi's power cables and mains filters runing into identical amps and calibrated Tvs....blind test results would be interesting.
i personally think there would be a difference just not sure the extra cost is worth it to me for an extra couple of percent improvement
fr0g's picture
Last seen: 4 months 2 weeks ago
What would the difference be down to?
If the bits coming from the player through the HDMI lead are not bit-perfect, for a start you will not get DTS, DD etc.
There is no scientific reason why they should differ, other than the very real effect of expectation. A shiny tank-like £1000 player looks a hell of a lot nicer than a Hwang-chong (or whatever), but if the Hwang-chong can deliver the same bitstream to the TV or receiver, then it will look and sound identical.
The PS3 looks, and sounds...identical to any other player, provided it works to spec.
Unfortunately, most people don't stop and think about it. They "expect" one to perform better than the other, and it does...for them. That's how there are differences...
And that includes the WHF test crew.
No answer yet from WHF on this question?
ellisdj's picture
Last seen: 5 days 22 hours ago
I have made my point pretty clear on here as to what I think on some players vs others.  Its only based on my experiences at the time - I know a lot of others see no difference at the same time so go with what you think is best for you
I would like to get an oppo to try out, that wont happen sadly.
I found out today that the McIntosh Blu Ray Player $8000 is based on the Marantz 7007 - says a lot about that design potential when there are not tight budget constraints.
https://upgradecompany.com/upgrade-company-products/marantz/product/33-marantz-ud-7007-signature-edition-upgraded-universal-player
If anyone is shopping buy the upgraded one Smile
System Thread needs to be done
Pages
Log in to post comments
