10 posts / 0 new
Last post
hyettdman's picture
Last seen: 3 years 7 months ago
denon 2012
what is the sound like on the denon 2012 bluray player, has it got a lot of bass weight,because thats what sound i'm looking for.the marantz 7006 sound is really thin and has literally no weight at all.
bigboss's picture
Last seen: 2 days 21 hours ago
RE: denon 2012
You need a subwoofer Wink
Seriously, what's the rest of your system like?
hyettdman's picture
RE: denon 2012
i've got b&w cm5's front dynauduio centre and b&w 686 at the back and a denon 2310 amp
hyettdman's picture
RE: denon 2012
and a rel t1 subwoofer
hyettdman's picture
RE: denon 2012
bigboss's picture
RE: denon 2012
I don't think your blu ray player is to blame here. The heart of any system is the AV receiver, & that's the weakest link in your system. Have you checked the settings of your receiver? Make sure you have set the speakers as "small" so that the subwoofer gets more work.
grifz's picture
Last seen: 3 years 9 months ago
RE: denon 2012
The Denon 2012 and the Marantz 7006 are the same machine under the bonnet. Have a quick read  of the WHFI review of the Denon 2012.
hyettdman's picture
RE: denon 2012 RE: denon 2012
in reply to bigboss, i've set my speakers to small before and i found that setting speakers like that you then lose a full bodied surround experience,and the subs just blasting away,making a very uncomfortable listen.
bigboss's picture
What's your crossover set at? Looks like you've set your crossover to too high. I'm convinced that tweaking your settings will solve your problem, & not changing a blu ray player.
bigboss's picture
RE: denon 2012
That is correct.
Log in to post comments
