Correct sound setting for Sony bdp-s380
10 replies [Last post]
near dark
near dark's picture
I have the above blu ray,and was wondering if the spund setting ate correct please
Audio (hdmi). Auto
Dsd output mode. Off
Bd audio mix settings. Off
Dolby digital  Dolby digital
Dts. Dts
Dts neo 6.  Off
Audio drc. Auto
Downmix. Surrond
I have a Yamaha rx-v371 and Dolby digital true hd appears
psurquhart
psurquhart's picture
RE: Correct sound setting for Sony bdp-s380
I have a Sony 370 - exactly same settings / set-up.
As long as Dolby True HD / Master HD shows up you are all good to go.
The only setting I would change would be to turn off Audio DRC.
In Sony land AUTO just means ON.
__________________
near dark
near dark's picture
Hi and thanks for the help,hd does appear on the av amp Laughing But could you explain what Audio drc is and does please.
Thank you
near dark
near dark's picture
Thank you
near dark
near dark's picture
Thank you
near dark
near dark's picture
Thank you
near dark
near dark's picture
Thank you
The_Lhc
The_Lhc's picture
STOP!!!!
It's Dynamic Range Compression, makes the difference between the quiet bits and the loud bits less, which is great for late night low volume listening but for normal listening you don't really need it.
__________________
No signature worth mentioning...
near dark
near dark's picture
Sorry all have no idea why the reply appeared so mant times ,how embarrassing .
Thanks for the explanation ,cheers
psurquhart
No problem and hey dont get embarrassed - its just What Hi Fi's "sleek" interface on replying to posts.
You think nothing is happening, get confused and hit save again.
It happens to us all - hey at least your a keen poster, welcome on board Smile
Dont worry about The_Lhc - he can be quite amusing at times. ;)
__________________
near dark
near dark's picture
Thanks will do
