CA 651 vs 751, DEMO TOMORROW AT RICHER SOUNDS ANY SUGGESTIONS OR ADVICE
19 replies [Last post]
surroundman
surroundman's picture
Hi guys,
 tomorrow I have chance to see and listen to CA
Anyone can compare these 2  players ?
Many thanks.
BenLaw
BenLaw's picture
Online
RE: CA 651 vs 751, DEMO TOMORROW AT RICHER SOUNDS ANY
What sort of advice?
__________________
HiFi   /   A/V   /   Bedroom
surroundman
good question,
what is the best way to do demo and recognize quality of both CA ?
thank you
surroundman
If I send PCM via HDMI to a receiver, then the digital to analogue conversion will be done by the DACs in a receiver.
Ok, if I got Yamaha RX A 2010 and player is CA 651 or 751 I suppose that set the  bitstream on player will be sound better  and then the digital to analogue conversion will be done by the DACs in player.
In what cases should player be set as PCM ??
BenLaw
BenLaw's picture
Online
Test upscaling by: comparing a few DVDs with which you are very familiar.
Test HD material with a few blu rays. IMO these should look identical.
You could test audio decoding by setting both to PCM via HDMI. However, it may be easier / more important to use the analogue outs on the blu ray players as that will test the DACs and analogue outputs.
__________________
surroundman
Thank you Ben
I have seen your photos of your home cinema.
May I ask you about location of your receiver, it looks like there is no too much space for ventilation.
I just wonder because usually in manual they say ,, allow  xx cm above and etc.
anyway my Yamaha they say should have above 30 cm above and 20 from side, but it is difficult to find proper self or rack fot that.
RobinKidderminster
RobinKidderminster's picture
Cool advise
I use a small fan from Quietpc. Can be virtually silent and keeps things very cool
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1Base trap Project - http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-pro... treatment - click for pics : Room pix - Clicky : Old setup - Clicky
BenLaw
BenLaw's picture
Online
surroundman wrote:
Thank you Ben
The 'receiver' is a pre/pro so doesn't have any amplification inside it. The primare is the power amp and runs pretty cool. Having said that, the onkyo does run quite hot. I have adjustable shelves and after a spring clean a while ago I moved the shelf with the bdp on it up and there is now plenty of room for air circulation. The unit is open at the front and back.
Let is know how you get on with your demo, I'm sure people will be interested to hear.
__________________
strapped for cash
strapped for cash's picture
I couldn't agree more. In fact, I'd push analogue stereo testing to the top of your list of priorities, assuming you don't have a dedicated stereo system.
I have a Yamaha Aventage receiver and I've found it highly advantageous to decode stereo externally of the receiver (multichannel is a different matter since, in my opinion, Aventage receivers are exemplary performers when it comes to multichannel decoding and surround steering).
There are arguably two reasons for buying a higher end BDP such as the Cambridge players you're looking at. First, DVD upscaling may be better than budget level models, though I've struggled to see much difference between a high end Denon BDP and the sub-£100 Panasonic 120 Blu-ray player when testing back to back at home.
More importantly, CA (along with Oppo) BDPs are sold on their analogue performance. I think the CAs you're auditioning will have superior DACs to your Yamaha when it comes to stereo. If you can't notice much difference, I'd start to question the value of spending that much on a BDP.
surroundman
Thank you very much guys for advices,
I have already been at Richer sounds.
There were: Onkyo 818, CA 751, M A speakers-Bronz
1.We tried analog, pure direct mode, CD Robie W.
It sounds overbassed,
2.After we tried digital, it sounds overbassed, but better more live than analog.
DVD Terminator Salvation sounds very good nearly as Blu ray disc( which I did watched before on my older Yamaha 1065)
DVD Coldplay it sounds better than on my PS3 slim
Now, is it any good way how to adjust bass on CA or it will always be lit bit more.
They said I can buy 651, if I plan to have only digital HDMI connection which I will do.
But we did not try CA 651 because they have last sealed piece
So I can borrow open box CA 751 and tried at my home with my Yamaha RX A 2010 and MEzo 6 and MEzzo 1, B&W HTM62-centre, KEF 1000.2 sub
and try to do something with bass.
WHat do you think ??
duaplex
duaplex's picture
RE: CA 651 vs 751
The 751 has just dropped to £549. They are now being discontinued and that to me is a bargain.
__________________
Panasonic 65" 3D TV (P65VT50), Pioneer LX83, CA, Azur 751BD, PS3, Water Cooled Xbox 360 (Modded), Nintendo Wii U, Sky HD+, i7 PC overclocked with 6850 HD Radeon, CM8 Fronts (Bi-Amped), CMC Center (Bi-Wired), DS3 Dipoles, PV1 Sub. Van Den Hul M.C. Snowtrack >Halogen Free< wiring, Chord Active Silver HDMI's, Cabridge Audio AUD700 Analogues Interconnects, QED Signature Subwoofer cables, Chunky Monkey custom oak AV cabinet.
surroundman
RE: CA 651 vs 751
yes that is true,  I was thinking also about  Panasonic dmp-bdt500 but according one review it sounds same as 220 or 320, and very similar as 120
which I got at home that is why is not point to demo Panasonic dmp-bdt500. It will be not improvement compare to my PS3 as well.
So I can see it probably on  CA
abacus
abacus's picture
If you like listening to music then definitely have a listen to the Panasonic 500, as when I compared it to the cheaper models from Panasonic and other manufactures, I found it to be way better. (Make sure you set the Panasonic 500 to do the conversion to analogue from digital, as if you use bit stream the sound will be determined by your AV amplifier, thus no matter what player you plug in they will all sound the same)
Hope this helps
Bill
bigboss
bigboss's picture
Online
RE: CA 651 vs 751
Make sure you check audio via analogue connection when you demo at home. If you can't hear any appreciable difference, you can save a lot by going for a budget player.
__________________
surroundman
RE: CA 651 vs 751
Ok if I set up player for PCM,  then receiver will show me only PCM format not DTS or DTS HD, not even Dolby digital ???
Then what is the point ? If I have PCM, it is the same as I listen and watch freeview broadcast.
duaplex
duaplex's picture
RE: CA 651 vs 751
Not entirely so, the BDT500 Is a great player and came second to the CA during my demo for bluray playback. Out of all budget decks this is the one I would consider a compromise to buying the CA.
The PS3 is good, but the new players are overtaking it. It's also noisy.
Interestingly enough I also had a demo of the S790 and that didn't look as crisp with detail.
__________________
