Bluray player output says...........
Thu, Mar 7 2013, 6:28PM
1080P / 24hz.......is that right?
I seem to remember it say 24fps previously.....I have had to mess with settings as the player got a some memory bug (fixed by USB stick in the rear) so just wanted to check I had reset correctly.........?
24Hz means 24fps, so you don't need to worry.
