Blue Ray Movies freezing during play
Hi All,
When i play some blue ray discs the picture freezes momentarily on a regular basis , my blue ray palyer is a Denon 2012.
Anybod with any ideas?
Kawal
Does this happen with just rental Blu-rays, or all of them?
The freezing only occurs on a couple of blue ray discs, is it dirt ?
Kawal
Same problem and it is not a dirt! Looking for help!
I get the same thing happen on some rental discs & the odd retail disc with my sony s380,mmm most odd.
It depends which Blu Ray player you have. My Pioneer is very sensitive to any marks on discs, so I can only play new, or as new discs, so no rental discs for me.
Only thing to do is update your firmware to the latest one, and only play scratch and finger print free discs.
So as yet we have no idea what discs you are having issues with.
So general fixes update your firmware. Make sure the disc is not damaged.
Or just provid more info on what the discs are that you are having isusses with then people can see if they are ones that are known to have problems or if they had the same problems how they fixed t.
All I can say is that I have not had anny issues with any discs.
You're very lucky, I had so many problems I've pretty much given up on Blu-ray.
Such as?
It drove me so mad that on more than one occasion I've nearly ripped the BDP out of the rack and thrown it out of the window. It's fine with DVDs, so that's what I'm sticking with for now.
I'm another one of the lucky ones - never had any issues playing any Blu-rays (apart from a couple from Lovefilm which were covered in fingerprints!).
Am now desperately touching any wood I can find
I'm sitting on a wooden chair!
My trusty Denon 2500BT has never let me down.
the disc may pause at the layer break, it does the same on dvd as well for a split second
ive got 2 sony 380 and never had a problem and its not on the latest firmware either
and ive got about 600 blu ray films
Which movies? And where? And is your firmware upto date?
Not a HiFi Nut. Just has a pile of Nads.
