Blu-ray Upgrade from Sony BDP-S370
Hi there, can anyone tell me the most cost effective upgrade to this player please?
Thank you.
Tosh 42" and Yamaha surround sound. I was wondering if it was worth the upgrade as I get a little motion judder when panning.
Do you have the blu ray player set to 1080p/24, and can your tv handle this?
Might be worth playing around with your tv and blu ray settings when you play blu ray discs.
I went from what you have (still use it upstairs in bedroom) and I agree with you about the motion judder.
I upgraded to the Panasonic DMP-BDT500.
This is a brilliant player - the best I have seen for motion judder - theirs nigh on none and the picture quality is so much more detailed too than your/our Sony.
It does have it's downsides too but not much - no sacd, networking the thing is impossible for a simpleton like me (although it can be done) - far too complicated, the remote is a pain.
If its just pure picture quality that you are after then it's a great player for not alot of money if you look around.
Of course, if you are used to a Sony and like them (their menu systems are probably the best), then theirs always the new S790 which is a belter too.
I suggest that would be the new BDP-S390?
Haven't seen you around for a long time!
Duplicate.
Hi there, yes it's those settings. TV ok.
- Login to post comments
Is it broken? Whats yr other kit? My similar upgrade acheived little. Budget? What weakness are u finding? What improvement r u looking for?
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1Base trap Project - http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-pro... treatment - click for pics : Room pix - Clicky : Old setup - Clicky
