Blu ray upgrade
Sun, Oct 9 2011, 11:31AM
Looking to upgrade my blu ray player. Wanting better pictures , rather than sound. Budget upto 750. Current player set up is : Samsung TV LED UE 40B7000, with sony BDP-S360 blu ray player and sony DAV-DZ700 cinema sound box.
The sony does take a long time to upload and can freeze frames on playing the dvds. Any help much appreciated as there is so much choice out there.
- Login to post comments
If I were you, I'd take your current Sony and try and compare with it with as many of the likes of the Panasonic DMP-BDT210, the Pioneer BDP-LX55 (as and when released), the Marantz UD5005, the Cambridge Audio Azur 651BD and the Denon DBP-2012UD as you can. Forget how much each player costs and just compare the relative merits compared with your Sony.
Once you've decided which provide a big enough step up in quality to justify a new purchase (assuming one does, many people have found they can't perceive any differences), you can then judge whether the outlay is worth improvement and hey presto, you can make a choice
