Blu ray players with 2 HDMI out
15 replies [Last post]
lapuzrg
lapuzrg's picture
Hi everyone. I am planning to buy my first ever blu ray player. However, I am looking for one which has 2 HDMI out 'coz I plan to use it as 1.) Blu ray/DVD player and 2.) cd player. My A/V receiver is a Marantz NR-1402. I would like to hook it on my Sony LED TV via the HDMI for watching movies and the second hook-up will be to the receiver for my music. Am I doing the right thing here?
Appreciate your good advice on this matter. My budget is around US$300.00. Any suggestions for a good Blu ray player?Smile
Kind regards,
Ron
__________________
Hi-Fi : Marantz NR-1402 - Polk Audio TSi-300
Eye-Fi : Sony BDP-S370 - Sony LED TV 32EX52 - Run through my Hi-Fi
bigboss
bigboss's picture
RE: Blu ray players with 2 HDMI out
Pioneer LX55 or Panasonic BDT310 will suit your requirements well. I don't know how much it would cost in your country.
__________________
lapuzrg
lapuzrg's picture
Thanks for your valuable suggestion, Boss.Smile
__________________
Paul.
Paul.'s picture
Online
If its any help,  I own the panasonic 310 and rate it highly.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
lapuzrg
lapuzrg's picture
Thanks, Paul. I am leaning on getting the Panasonic as per Big Boss and your suggestion. The reasons :
1. Built in wifi
2. Touch free sensor ( I think this is cool :clap:  )
3. Skype feature
Smile
__________________
The_Lhc
The_Lhc's picture
I don't see the point of this, does the receiver not have an hdmi out for you to connect to the TV? Then you could use the receiver for movie audio as well. The only reason to do this is if you want to watch 3D movies on the TV and the receiver doesn't support 3D pass-through (I don't know if this is the case or not).
__________________
No signature worth mentioning...
lapuzrg
lapuzrg's picture
Hi The Lhc, yes, it has an HDMI out (1), so how do I do it? Mind giving me the correct way of connecting the various components (Marantz NR-1402 A/V receiver, Blu ray player) to each other.
Really appreciate your help..Smile
Thanks & best regards,
__________________
The_Lhc
The_Lhc's picture
Umm, unless I'm missing something about the Marantz (that's entirely possible!), HDMI from the blu-ray to the receiver's HDMI input and then another HDMI from the receiver's HDMI output to the TV.
__________________
franklin2829
franklin2829's picture
Kind regards,
Ron
HI,
I would go for the Pioneer BDP LX55.
Chris
__________________
Chris Sullivan
Director at Pixll
professorhat
professorhat's picture
Nope, nothing being missed that I can see - should work as noted above. The Marantz has HDMI 1.4 compatible inputs and output as well, so will even pass on 3D Blu-ray to your TV if you ever need it.
Absolutely no need for a player with two HDMI outputs at all.
lapuzrg
lapuzrg's picture
Hi Chris, thanks for your advice. Really appreciate it. Smile
__________________
lapuzrg
lapuzrg's picture
Thanks, Professorhat for your sound advice. That being the case, I don't need a player with 2 HDMI outputs, one output will do the job?good job
__________________
lapuzrg
lapuzrg's picture
__________________
The_Lhc
The_Lhc's picture
You're welcome...
__________________
professorhat
Yup, just one output will do the job.
And to be fair, it was The_Lhc who noticed this so he deserves the thanks - I just looked at the manual to check if it would pass 3D or not...
professorhat
Duplicate
