blu ray player audio
I currently have a surround sound set up that i'm happy with for now but it is a few years old
as such the amp does not have an hdmi input
i'm about to purchase my first blu ray player and obviously want to use it with my system
am i right in saying what i need therefore is a blu ray player that decodes the audio onboard and then outputs it via a multi channel output?
if so can anyone recommend a player that will do the job for under £250
cheers
No, the Sony doesn't have multichannel analogue outs. Assuming the OP's receiver has the requisite multichannel analogue inputs, something like the Panasonic DMP-BD85 looks like a safe bet, and can still be found for around the £150 mark.
Yes, there is no much choice in that price class. Except if you want to take a chance with Philips BDP9500 that use Burr Brown decoder, but it may have other issues. By some distributors you may also find Yamaha BD-S1065 in range.
Did you notice any difference in CD/MP3 or other sound performance over analogue connection between DMP-BD80 and DMP-BD85?
Oops sorry about that my mistake, it only has analog audio 2ch output.
Its better to have 2 high grade outputs then rubbish 5.1. All the material is originaly recorded in 2 channels, so all the rest is fabricated sound only.
- Login to post comments
I would advise you to have a demo of the Sony BDP-580 as i believe it does have your required analogue outs found here Clicky
Regards ..
My System
Sony Bravia 46HX853 Calibrated Settings
