3d Blu-ray Players with Dual HDMI out or HDMI splitter solution?
9 replies [Last post]
micks_address
micks_address's picture
Hi Folks,
Apart from the Panasonic BDT310, around the same money - is there any 2d blu-ray players with dual hdmi out? I need to be able to run HD audio to my denon 3310 and 3d direct to the tv.. is anyone successfully using a HDMI switch in a setup like this? If so what should I be looking for? Be nice to look at some other blu-ray players like the Sony's etc
Cheers,
Mick
__________________
Panasonic 42VT30 Plasma, Denon AVR 3310, Opp BD93, MA Radius 225HD left/centre/right, MA Radius 90HD surrounds, RSw12 sub, Harmony 1100 remote, Project RPM5 Turntable
Andrew Everard
Andrew Everard's picture
RE: Blu-ray players
It's unlikely that a HDMI switch would be suitable, as these usually only allow signal to be sent to one device at a time. Neither would an HDMI splitter be likely to do the job: IME, the HDMI output defaults to the lowest common denominator whensent through these devices, so the receiver's alck of 3D capability would probably stop 3D being sent to your TV. Or, at worst, these devices get confused when devices of two kinds are connected at once, throw an HDCP hissy fit and don't send anything at all anywhere!
I'm not aware of any other players at this level with twin outputs, but our test team may know better.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
TheHomeCinemaCentre
TheHomeCinemaCentre's picture
RE: Blu-ray players
It can be done with a swtich but as Andrew mentions there can be problems. There are work arounds to force the EDID to the 3D output - we use them when there is a 3D projector and a 2D TV for instance. Factoring in the costs I would suggest the BDP310 is the best and most reliable route though, or a new av amp.
__________________
Nick
The Home Cinema Centre
micks_address
RE: Blu-ray players
thanks guys, i'll see if i can get a 'quieter' bdt310 before pursuing this further..
cheers,
mick
__________________
grifz
grifz's picture
RE: Blu-ray players
Philips bdp7500 has Hdmi and  Hd Component outputs . I dont know if you can hdmi strait to tv and Hd component to amp
Andrew Everard
RE: Blu-ray players
Yes, it has multichannel analogue outs, so it would solve the problem provided the OP doesn't mind investing in three pairs of analogue interconnects.
The current MkII version would also address the 3D need.
__________________
micks_address
RE: Blu-ray players
thanks guys, i assume my denon 3310 has analogue inputs? I also assume I wouldnt get my nice blue light for lossless audio any more and the amp would just say 'Multi Channel Direct' or something like that? Is it generally accepted that there is no loss in audio quality going this way instead of bitstreaming to the receiver and letting the receiver to do the decoding? With the analogue outputs you set the player to do the decoding? I think there's a Samsung model that also offers analogue outputs.
Cheers for the help
Mick
__________________
Andrew Everard
RE: Blu-ray players
Yes, it does, just above the centre and surround speaker terminals.
Correct.
Provided the player has reasonable decoding and analogue outputs, as is the case here, yes.
Yup.
__________________
maxflinn_banned
maxflinn_banned's picture
RE: Blu-ray players
thanks guys, i assume my denon 3310 has analogue inputs? I also assume I wouldnt get my nice blue light for lossless audio any more and the amp would just say 'Multi Channel Direct' or something like that? Is it generally accepted that there is no loss in audio quality going this way instead of bitstreaming to the receiver and letting the receiver to do the decoding? With the analogue outputs you set the player to do the decoding? I think there's a Samsung model that also offers analogue outputs. Cheers for the help Mick
clicky
__________________
laptop...airport...marantz pm7001...dynaudio dm 2/7's...
simoncar
simoncar's picture
RE: Blu-ray players
Hi Mick,I think you should stick with the pana 310,just get one from another retailer. Smile
__________________
LOUNGE-panasonic 50 VT30,panasonic BD310,sky HD,ps3 250g,Denon 2310,kef 3005,kef iq50se fronts,all chord hdmi,all QED speaker cables.
CONSERVATORY-panasonic 42 V10,sky HD,ps3 60g,onkyo 606,jamo hcs2 5.1,cheap hdmi,all QED silver micro.
