9 posts / 0 new
Last post
mattjax05's picture
Last seen: 3 years 1 week ago
3D auto-detection help
Tried my first 3D blu ray (Dredd) and my tv wouldn't auto-detect the 3D signal. Setup is Sony BDP-S490 to Yamaha RX-A1010 to Panasonic 50GT50. 1.3 HDMI cables. I plugged directly into tv and it worked then plugged through amp and it worked. Turned everything off and tried again and it didn't work. But then an hour later it worked. Now it doesn't work! Is this a common problem - not a good start to my 3D experience.
strapped for cash's picture
Last seen: 3 months 1 week ago
RE: 3D auto-detection help
I'm guessing the problem lies with your cables. You're using older HDMI leads that aren't technically "3D ready."
mattjax05's picture
So it's possible the cables can intermittently accept the 3d signal?
I've no idea why that would be the case, but you're not using HDMI cables specified for 3D use. Your cables therefore seem the most likely cause of problems with 3D playback.
I can't state definitively that switching to "3D-ready" cables will fix the issue, but lower specification HDMI leads seem a likely culprit, based on your description.
Beyond that, it could be a settings issue. Have you checked all your hardware to ensure that 3D modes are engaged? Sometimes you can inadvertently disengage a feature.
mattjax05's picture
After some research I am led to believe any 'high speed' hdmi cable is capable of transmitting a 3D signal.
gel
gel's picture
Last seen: 5 days 4 min ago
I think that is correct.
Stop
Well, you identified your HDMI cables as v1.3. While the 1.3 nomenclature is technically no longer used, a v1.3 cable isn't officially "3D ready." It doesn't automatically follow that all v1.3 HDMI leads won't pass 3D data.
Did you check settings on all your hardware to confirm that you haven't inadvertently switched off 3D functionality somewhere in the AV chain?
What cables are you using, specifically?
mattjax05's picture
I quoted 1.3 as, at the time of purchase of the cables, 1.3 was used as a selling point. They're a QED perfoance and Chord Silver Plus. 1.3 = high speed which is what I understood when I bought these cables years ago. I didn't realise these version numbers are no longer used in marketing until today when I researched HDMI cables on the web and again I didn't realise you only need high speed cables for 3d/ARC/4k etc. Glad I researched.
The 3d link has worked on the last two attempts so going to persist with the current cables.
themovierooms's picture
Last seen: 1 year 6 months ago
These cables will work 100% for 3D.
Have you checked that all of your software is up to date on BD, Amp & TV?
I have found that some disks don’t flag the 3D in Auto on the Panasonic sets (The James Cameron "Ghosts of the Abyss" was one), can you check the 3D setting options or force it into 3D with the button on the remote?
Log in to post comments
