Yamaha v673 and Monitor audio Mass - is this a good combination
4 replies [Last post]
letmeboogey
letmeboogey's picture
Hi All
After my last post i am now going for a Yamaha v673 with Monitor audio mass speakers, as i want  it to go with my Pana 55vt50 and panasonic bdt500 blu ray.
Is this a good combination ? t would be good to also hear from people with this setup too. What is an excellent hdmi cable to go with this setup as we are now also planning to put the tv on the wall ?
What reasonble priced speaker cable would you recommend ?
Any help is fully appreciative
bigboss
bigboss's picture
RE: Yamaha v673 and Monitor audio Mass
1) It's an excellent combination.
2) Don't spend too much on HDMI cables. There's no performance difference in my experience. I've got £5 cables from ThatCable.
__________________
MUSICRAFT
MUSICRAFT's picture
RE: Yamaha v673/Monitor audio Mass - is this a good combination
Hi letmeboogey
The synergy between Yamaha's RX-V673 AV receiver and Monitor Audio's Mass sub/sat speakers is superb Smile Yamaha AV amplification and Monitor Audio speakers form a great match (time after time) rockin out
Btw, standard 79 strand OFC speaker cables will be good enough for the RX-V673/Mass pairing.
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
Ketan Bharadia
Ketan Bharadia's picture
It's a good set-up. One that works well across the board.
__________________
Technical Editor, What Hi-Fi? Sound and Vision
Son_of_SJ
Son_of_SJ's picture
Online
RE: Yamaha v673 and Monitor audio Mass - is this a good combinat
As the other folk have said, that's a terrific choice of receiver, television and blu-ray player! Smile
HDMI cables - I tend to use Lindy, based in Teesside. For instance, a 2m HDMI cable for £9 http://www.lindy.co.uk/2m-premium-high-speed-hdmi-cable/41112.html. They also sell more expensive ones with Ethernet connections, if you need that, and much more expensive blue-braided ones (cost about £60!) but I've not noticed a difference between those and the much cheaper one in the link.
Speaker cables - I've not done a comparison with any other cables, but I use Richer Sounds' Cambridge Audio SYMPHONY 400, £2.49 per metre http://www.richersounds.com/product/speaker-cables/cambridge-audio/symph....
