5 posts / 0 new
Last post
admin's picture
Last seen: 15 hours 5 min ago
Yamaha RXV-667 and Xbox 360 HDMI problem
Hi all, searched on google and can't find any forums on this problem so here goes:
I used to have an old 1st generation Xbox connected to the receiver via component cables and it worked fine. Today I got a new Xbox with a HDMI output but when I connect it to the receiver via HDMI I get a 'no signal' screen on the TV. I can't even bring up the reciever menu on screen. I can hear Xbox sound through the receiver's connected speakers.
If I connect to the receiver via the yellow, red and white cables all works fine but it is obviously low def. If I connect the Xbox via HDMI directly to the TV it works fine in HD but I don't want the extra cable dangling down.
My thinking is that it must be a synching problem with the receiver/xbox via HDMI. I have tried it on HDMI inputs 3, 4 and 5 but no joy. The inputs themselves do work as i've checked them with my freesat box.
Ideally, I would like it to work via HDMI so has anyone got any suggestions? I can't see any switches that I need to move etc.
Many thanks in advance
laserman16's picture
Last seen: 2 months 5 days ago
RE: Yamaha RXV-667 and Xbox 360 HDMI problem
Have you tried the HDMI socket on the front?
chris hollands's picture
Last seen: 2 years 10 months ago
Just a thought , you may need to adjust your screen resolution ?
simonlewis's picture
Last seen: 1 day 17 hours ago
I presume you have assigned the HDMI input on your amp.
Anonymous's picture
I'm not sure to be honest. Any other time I have used HDMI its been like a plug and play thing. How would i assign? Thanks
Log in to post comments
