Yamaha RX-V673 - No Signal HDMI Output & the red HDMI indication keep blinking
Tue, Jan 15 2013, 11:24AM
Tue, Jan 15 2013, 2:25PM
#2
Have you checked that the TV is set to the correct input?
Wed, Jan 16 2013, 5:56PM
#3
Have you tried checking that the HDMI's are pushed in properly at both ends from the TV to the amp & the other bits of kit? Mine came loose & i got no picture from just moving the amp slightly when giving it a clean.
Regards ..
Sat, Feb 23 2013, 10:49PM
#4
Any luck on this issue? I have the same problem.
I am currently using Yamaha RX-V673. I have been using this machine for 6 months now and I am very happy with it. It deliveres fantastic sound!!! However, last night after i reached home and tried to watch TV (cable TV), unfortunately, I can only hear the sound but no video. The TV showing "NO SIGNAL" and I started to panic. Then I switched to other sources, PS3, Blue-Ray Player and it is still the same, No Signal. Then I noticed the HDMI output light indicator keep on blinking. Could someone really help me to solve this problem.
