7 posts / 0 new
Last post
nugget2014's picture
Last seen: 1 day 13 hours ago
Yamaha or Denon av receiver?
i said to myself i would buy the denon AVR-X2000 for some time now.
but i just seen the new range of yamaha receivers on their website but cant find the pricing anywhere. how much will these be around?
and now i question myself. do i go for a denon or a yamaha? it would have to be a 2013 model as the new ones will be too expensive i am guessing (£250-300 budget)
i dont need an av receiver which has good treble etc as i hear some can be bright at high volumes
i just want good connectivity (airplay, maybe wifi)
good picture quality
and good sound quality
with decent reliability
i can afford the following receivers:
denon avr-x2000
yamaha rxv-575 and rxv-675
onkyo txnr626
the onkyo doesnt have airplay which i will be using to play music from iphone..DLNA is useless as i only have an iphone. so i dont think i'll even consider this. but what are your thoughts of this avr?
Setup: Samsung UE55JS8500, Samsung UBD-K8500 4K Player, Dali Zensor 3, Dali Vokal Centre, Denon AVR-X2200W, Arendal Sub 1, Monitor Audio Radius 45, Elac Debut Atmos
Laurens_B's picture
Last seen: 7 months 3 weeks ago
RE: Yamaha or Denon av receiver?
A couple of weeks ago I tested the Yamaha RX-V675 and the Denon X-2000 next to eachother. The things I noticed:
- The X-2000 tended to sound much more bright when playing at high volumes, to the extent that it was unpleasant to listen to. Then again, the connected speakers were horn-loaded so this effect might be less present with other speakers. Still, the RX-V675 was smoother at high volumes.
- The Yamaha runs much hotter than the Denon, which might be something to think about when you will placing the receiver in a closed cabinet.
- The X-2000 is smaller than the RX-V675 (especially in depth). This might be an advantage for you.
- If you use spotify, the RX-V675 has spotify connect, for which there is no decent alternative on the X-2000.
- If you are planning on connecting a home cinema set, the Yamaha tends to drop dramatically in power output per channel when 5 channels are connected. This is less with the Denon. If you are only using 2 channels, this doesn't matter at all. (If you are planning in connecting a complete home theater system, I would aim for the Aventage series anyways).
All in all, I liked the RX-V675 more, because it sounded less bright.
As always, it would be best to be able to audition them with your speaker set.
Speakers: B&W 683 S2 - Pre-amp: Emotiva UMC-1 - DAC: Emotiva XDA-1 - Power-amp: Emotiva XPA-5
cant the denon's problem of sounding bright be solved by keeping the treble at +0? i always have my bass and treble boosted to +10 on my rcd-n8 music system. dont know if i will use any eq on a/v receivers. thats if they even have option to change the treble and bass volumes!
Sliced Bread's picture
Last seen: 1 week 18 hours ago
You can, but where possible you'll be more likely to get a satisfying sound if you have an amp which is closer to your tastes out of the box.
fitnessfun's picture
Last seen: 2 years 8 months ago
What about the Marantz NR1420? It was ranked high here http://www.squidoo.com/best-av-receiver-for-the-money and it it under your budget.
ClassAct's picture
Last seen: 8 months 1 week ago
Gospel to SlicedBread's comment  :cheers: You want something you're going to enjoy getting on with straight out of the box.
purchased the sony str-dn1040 in the end for £299 at richer sounds Smile
Log in to post comments
