Yamaha amp just switched off
7 replies [Last post]
near dark
near dark's picture
My yamaha amp just switched its self off. I don't know if is due to the amps protection ,but he amp was on for almost 10 hours .
Should I be concerned as its only two months old.
David@FrankHarvey
David@FrankHarvey's picture
RE: Yamaha amp just switched off
What volume was it on when it switched off? And which speakers are you using?
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
near dark
near dark's picture
It was -18 and just the front left and right ,was watching a two channel DVD.
Petherick
Petherick's picture
Hi near dark
Which Yamaha amp is it? I had a problem a while ago with my RX-V667 which was resolved by doing a factory reset and then installing the latest firmware. There's a series of 'button press' steps to do this; I can't remember them off-hand but I have a note of them (somewhere).
In my case, the amp appeared to switch on but no input could be selected, so it was in effect in a standby mode. I got great help from the Yamaha team - there's a link on their website. But if it's only 2 months old and you bought it from a dealer, the first recourse should be to contact them.
__________________
near dark
near dark's picture
Its a Yamaha rx-v371,I bought it from richer sounds,I phoned them and they said it was probably due to the time it was on,so to prevent damage.
They said to keep an eye on it and see if it happens again.
David@FrankHarvey
So were the front two speakers running full range from a Dolby Digital or DTS signal? Or even worse, full range from a master Audio/True HD signal?
__________________
f1only
f1only's picture
He says a 2 channel DVD in his post David
near dark
near dark's picture
Hi,Just the two channels ,thanks
