7 posts / 0 new
Last post
RealX11's picture
Last seen: 3 years 3 months ago
Yahama RX-V375 impendance (Ohms) Setup
Hello,
I bought "RX-V375 AVR" , "NS-PA120 5.0 speaker System" and "YAMAHA YST-SW 216 Subwoofer"   Speaker System from MediaMarkt Germany.
The impedance value of NS-PA120 5.0 speaker System is 6 ohms, but the factory value is 8 ohms.I tried 5 steps mentioned below on AVD machine, but I could not see "SP  IMP" menu.
1- Before connecting speakers, connect the power cable to an AC wall outlet.
2 - While holding down STRAIGHT on the front panel, press (power).
3 - Check that “SP IMP.” is displayed on the front display.
4 - Press STRAIGHT to select “6Ω MIN”.
5 - Press (power) to set the unit to standby mode and remove the
power cable from the AC wall o
To sum up, How can I make impedance value as 6 ohms on RX-V375 AVR, rather than 8 ohms?
Coult you help.
Petherick's picture
Last seen: 1 week 3 days ago
Hi RealX11Only US and
Hi RealX11
Only US and Canadian models can be switched 6 or 8 ohms. I assume you are not in US or Canada...
For other models, the manual states "Use speakers with an impedance of at least 6 ohms", so your speakers should be fine.
RealX11's picture
RE: Hi RealX11Only US and
Petherick wrote:
Hi RealX11 Only US and Canadian models can be switched 6 or 8 ohms. I assume you are not in US or Canada... For other models, the manual states "Use speakers with an impedance of at least 6 ohms", so your speakers should be fine.
The speaker I use is 6 ohms. The factory setting of AVR machine is 8 ohms.
Does not it create a problem?
Petherick's picture
RE: Yahama RX-V375 impendance (Ohms) Setup
I am going by the user manual and the specifications here - http://europe.yamaha.com/en/products/audio-visual/av-receivers-amps/rx-v375_g/ which states 6 ohm speakers are suitable.
RealX11's picture
So,
Do not need to make any adjustments.
Right?
Petherick's picture
Right!
RealX11's picture
Petherick wrote:
Right!
Thank you Smile
Log in to post comments
