Y-splitter for subwoover
11 replies [Last post]
surroundman
surroundman's picture
Hi guys,
is it worth to buy Y-splitter for subwoover ?
drichardb
drichardb's picture
RE: Y-splitter for subwoover
I've read stuff about this in the past and the general opinion is that there is no harm in doing so.  But I think its fair to say that if your not happy with your subs performance with a mono connection, it is highly unlikely this will change by adding the Y-Splitter.
__________________
My Setup
Benedict_Arnold
Benedict_Arnold's picture
It doesn't do any harm, and if the rumble is tracking from one side to the other it's a definite plus.  However, if you're receiver doesn't have separate sub-left and sub-right terminals, and you are driving your sub off a single sub-out terminal on your receiver you're probably using an already merged left-centre-right signal anyway.  If you're driving off the speaker terminals, however, I'd avoid it, as you could drop the speaker impedance too low for the power amps to cope with.
michael hoy
michael hoy's picture
surroundman wrote:
Hi guys,
It can be beneficial and give a boost to the bass (3dB maybe). What cable are you currently using.
__________________
AV System -  Panasonic 42VT30 ¦ MA Apex 5.1- 4xA10 1xA40+ AW-12 Sub ¦ Van Damme UP LCOFC Speaker Cable ¦ Pioneer SC-LX85 ¦ OPPO 95 ¦ Mark Grant G1500HD Precision audio cable ¦ Sky+ HD(1TB) ¦ Chord Active HDMI ¦ Belkin PF50 mains conditioner.
Bedroom - Sony KDL-40W2000 + Archos 7 streaming from Windows Home Server 2011, Altec Lansing inAir 5000.
Dining Room - Sonos S5.
Music - HP Proliant Server running WHS 2011 ¦ streaming FLAC to Sonos ZP90 and OPPO 95 via SC-LX85.
Hi Fi - Cyrus 8 XPd QX amp ¦ Cyrus PSX-R power supply acting as Pre Amp ¦ Quad 909 Power Amp ¦ Speakers - Spendor A3 ¦ Logitech Squeezebox Touch upgrade by Fidelity Audio ¦ power supply upgrade by Mains Cables R Us ¦ Power Plant Premier mains regenerator.
Controlled by – iPad2 and Harmony 1100.
surroundman
Hi Michael,
I am using ATLANTIC QUALITY INTERCONNECT FROM CAMBRIDGE AUDIO, that is written on it.
Sub is KEF 1000.2 and receiver: Yamaha RX A 2010.
It is not sound bad, but because I did not listen any better hard to say.
I have to make decision regarding all speakers, because I got Mezzo 6, mezzo 1 , central is B&W HTM62.
QUESTION IS GO FOR ONLY MEZZO, OR FOR B&W OR TOTALLY CHANGE BRAND.
I WOULD LOVE SOMETHING SMALLER, BUT NOT WORST THAN MY PACKAGE, BUT I DO NOT THINK IT WOULD MASSIVLY IMPROVE SOUND
IF I CHANGE BRAND, IT WOULD BE ONLY SLIGHT DIFFERENCE.
THANKS
michael hoy
If you are trying to improve the overall sound, I would not bother with the splitter. It will not help, and I would not recommened adding one for your sub.
What is it you are not happy with.
__________________
KiwiMoto
KiwiMoto's picture
I have Yam 3020 to Velodyne eq sub.Cable is micro QED.Sub needs manually switching on sometimes as it's not auto sensing signal.Will a Y splitter help?
__________________
Panasonic PT AE8000*Yamaha Aventage A3020*Pioneer BDP 450*Project RPM 9.1*Dynavector P75*Klipsch RF/RC/RS 62 II*Klipsch RS41 II front height/rear surrounds*Velodyne SPL1000Ultra*Da lite 110" 2:35:1*DVDO Duo i/p scaler*Apple TV 1080p*MySky HDi*Cables-Wireworld Chroma 6 HDMI/QED Silver Anniversary XT/Chord Crimson plus/Clearer Audio Copper line mains*Control4 automation*
michael hoy
It is possible this would help. However I would initialy try increasing the output on your amp for the sub.
 If using a "Y" splitter don'y use a cheap nasty one.
__________________
KiwiMoto
KiwiMoto's picture
Check my sig,I don't do cheap and nasty lol rolling on the floor laughing
I'll try upping the signal a wee bit and see if that helps first.
Failing that I'll see if I can get a titanium plated Italian designed Y splitter party time!
__________________
michael hoy
KiwiMoto wrote:
Check my sig,I don't do cheap and nasty lol rolling on the floor laughing I'll try upping the signal a wee bit and see if that helps first. Failing that I'll see if I can get a titanium plated Italian designed Y splitter party time!
Cool
__________________
michael hoy
__________________
surroundman
Hi Michael,
I just order single cable :
http://www.amazon.co.uk/Pure-Shielded-Subwoofer-Cable-Gold/dp/B003PU4VTS...
I think this will be ok, my previous cable was too loose on the sub end.
