Which of these receivers
8 replies [Last post]
ChrisDK
ChrisDK's picture
I'm looking into upgrading my Denon AVR2105, and I'm considering the following:
- Denon AVR2312
- Pioneer VSX-2021
- Yamaha RX-A810
- Yamaha RX-V2067 (as they are selling at a very reasonable price right now).
Any experience with any of the above? Any other recommendations?
Should I be concerned that the Pioneer is a bit lighter that then rest of the bunch? Have they saved on the quality of the AMP?
It will be running a set of Monitor Audio Silver RX (5.1 setup).
I have no experience with Yamaha. How is the sound compared to Denon? And what about the general quality?
__________________
markjaspi
markjaspi's picture
RE: Which of these receivers
I've not heard the new Pioneer or Yamaha, but the older 2067 and the RX will be a great match.
__________________
Panasonic 50GT30B | Marantz SR5006 | Boston Acoustics A26 front - A225C - A26 rear | Panasonic BDT310 | Sky+ 1TB HD | Virgin TiVo | iPad 2 | Samsung Galaxy SIII | New Apple TV | Control: Roomie via iPad & iPhone | Xbox360
David@FrankHarvey
David@FrankHarvey's picture
If you like the combination of the RX package with your current Denon, then consider the 2312 very seriously. This will be the easiest transition to make as you'll be used to the remote an menu system. Tonally, the Yamahs won't be too dissimilar, so either the 810 or 2067 will match in well too. Although if you can stretch to a 3067, that will bring out more of the RX's capabilities. The Pioneer will be a little more of a forward sound compared to the others, and would be ideal if you want more detail and little more excitement than you're currently getting.
And weight won't be an indication of quality. Most AV receivers at the same price point are going to be similar in quality, but they'll vary slightly in features or number of inputs. Build quality might vary slightly.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
MUSICRAFT
MUSICRAFT's picture
- Denon AVR2312
- Pioneer VSX-2021
- Yamaha RX-A810
Hi ChrisDK
I'll highly recommend Yamaha's RX-V2067 as ime Yamaha AV amplifiers form an excellent tonal match with Monitor Audio speakers time after time Smile At the current prices the RX-V2067 is really a bit of a no brainer excellent!
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
THESTIG08
THESTIG08's picture
denon would be my choice..i have not heard the new model but i have had the rx range with the denon 2310 and it was superb, you might even want to look at the denon 3310, these can be had for about £449.00 which will give you enough left over for quality cables..
__________________
Samsung 40" LCD -> Pioneer BDP-LX70A Blu-Ray -> Cambridge Azur 640C V2 (Transport) -> Rega Dac -> Rega Brio-R -> Kef R100 -> Partington Super Dreadnoughts -> Chord Epic -> Chord Cobraplus vee-> Chord Prodac x2 -> Logitech Harmony One
ChrisDK
ChrisDK's picture
*bump* Smile
I'm just reviving the thred as I'm still looking around.
I'm considering stretching my budget a bit and I'm also considering the following:
- Denon AVR 3312
- Yamaha RX-A1010
Would I gain much from the AVR's listed previously with either of these? They should obviously be better units that the AVR 2312 and the RX-A810, but how would they compare to the VSX-2021 and the RX-V2067 ?
I've been trying to find some reviews but seems most of these are too new for any reviews to really be online yet!?
__________________
Big Aura
Big Aura's picture
I auditioned the 3312 against the outgoing Pioneer SCLX73. The Denon came out on top for me.
__________________
I have some home cinema and Sonos stuff.
hortensio
hortensio's picture
Denon 3312 or Yamaha 2067/3067....you will not upset with each of these....they are perfect mates with MA speakers...
Hi-FiOutlaw
Hi-FiOutlaw's picture
hello everyone!
I am also in the process of acquiring an amp, I'm thinking of two Yamaha's RX-V771 in Portugal I can buy it for 599 (black) or the Pioneer VSX-2021 K (879 ) or the RX-A810 which I do not know the price yet ... The amp will feed my Monitor Audio B4 system.
I have an Ipad 32gb and Airplay would be welcome. But for 100  i can buy YID W10 to replace apple airplay ... Help please !!!!! I want to replace my old Yamaha RX-V 750.
__________________
LivingRoom
Rega RP3 / Goldring 1012gx # Synology DS213 > QED Performance USB > Rega DAC > QED Performance RCA > Rega Brio R > Supra Classic 2x4mm > Dynaudio Excite X12 and some times BK XLS200 MK II
BedRoom
SBT > G&BL teflon line RCA > NAD 3020i > Supra Classic 2x4mm > Monitor Audio RS1
