Which amplifier for Dali Fazon Satellite 5.1-3 system?
Mon, Mar 4 2013, 9:32PM
Tue, Mar 5 2013, 9:17AM
#2
I've heard the Yamaha, and was very impressed with it. It's also won awards, so comes highly rated. But if I were you, I'd demo them both and find out for yourself.
Regards
Tue, Mar 5 2013, 4:48PM
#3
Thanks for your reply.
Unfortunately, we're unable to find anywhere near us that sells both items so it is difficult to go for a demonstration.
Though after plenty of research and deliberation, have decided to go with a Denon AVR3313 amplifier.
Thanks again for taking the time to reply.
Paws here again,
I did type a message but for some reason it is not showing up. Two amps considering either Yamaha V673 or Pioneer SC2022? Any advice as to which would work best with Dali Fazon Satellite 5.1-3?
Thanks.
