What AV receiver for KEF 5005.2
9 replies [Last post]
swsuresh
swsuresh's picture
Hello All, I am buying a KEF 5005.2 speakers, found in Currys for 750£. . I have a 52HX903 TV, with a BDPS580(3D Blu Ray player). I would like what is best AV Receiver for this setup. My useage would be for movies and daily Sky HD viewing. Kindly let me know your thoughts
Note: I would like to know whether a Sony STRDH810 be a good choice?
MUSICRAFT
MUSICRAFT's picture
RE: What AV receiver for KEF 5005.2
Hi swsuresh
What is your budget?
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
swsuresh
swsuresh's picture
Hello,
 May be around 300-400 max, I found the Sony STRDH810 for around 200£, but one of my mate said the Denon 1912, which seems to be around 450£.
MUSICRAFT
MUSICRAFT's picture
Hi swsuresh
Thanks for your reply.
Also have a look at Yamaha AV amplifiers as IME these work very well with KEF sub/sats speakers  Smile The new RX-V671 should work just nicely with the 5005.2 speakers excellent!
All the best
Rick @ Musicraft
__________________
swsuresh
swsuresh's picture
Hello Rick,
 Thanks for the valuable information. The RXV671 is also around 499 mark and with extensive research I found the Onkyo TXNR609 to be better than the Yamaha & Denon 1912. Correct me if I am wrong.
d4v3pum4
d4v3pum4's picture
You asked what the best receiver would be with your chosen speakers.  Someone replies with a suggestion with what they consider to be the best match with the Kefs in their experience, yet you come back questioning it and you have no experience of either?  Go and visit a dealer and get a comparison between the two for yourself.  That is the only way to confirm it by using your own ears.
d4v3pum4
d4v3pum4's picture
David@FrankHarvey
David@FrankHarvey's picture
I would say either the 671 or the 609 as a starting point. Like the 3005's, the 5005.2's get better when you use a better receiver, so if you can stretch to go up the range a little more, you'll get more out of them.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
MUSICRAFT
MUSICRAFT's picture
swsuresh wrote:
Hello Rick,
Hi Suresh
I am sorry for my late reply Sad
Your welcome. The new RX-V671 has a RPP of £500. I know the 2005.2 speakers well as i used to sell these, other KEF KHT sub/sat speakers packages and i also owned KHT2005. Denon and Onkyo do work well with Kef KHT speakers however in my experience Yamaha AV amplifiers gel even more effectively with KHT speakers. Yamaha's overall tonal qualities combined with their Cinema DSP technology and KEF's UniQ technology compliment each other just nicely Smile
Comparing their audio performance i also prefer the RX-V671 to the TX-NR609.
All the best
Rick @ Musicraft
__________________
crasherkid
crasherkid's picture
I previously had a Yamaha with Kef and the tonal balance was superb, it really was.
Nobody can make the decision for you. You really need to go demo a few and choose what sounds best to you!
__________________
Stay away from me, I have been diagnosed with AV Upgradeitis
