Tannoy Sfx sub settings
Sun, Nov 11 2012, 5:50PM
just bought from richer sounds he tannoy Sfx sub.
i was wondering what the correct settings are for the sub,the actual controls on th rear of the sub.
there is power ,phase,crossover and level
any help is appreciated
thanks
ps, connected to. Yamaha rx-v371
Hi near dark
What speakers do you have to go with this subwoofer?
There are not any correct settings for a subwoofer to be honest just a good starting point. I would advise the folowing
Phase set on 0
Turn the gain or volume on it up to no more than half way
Lastly put the crossover setting at around 80Hz
When you have done this you will have to run the YPAO setup on your amp using the mic supplied by Yamaha. After callibration if the subwoofer is too loud you can turn it down on the amp in the speaker menu rather than on the sub as it steps down in 1/2dB steps so is easier to judge, especially if you dont have a SPL meter using the test tone option.
Note: Position in a room will alter the sound from it dramatically
Regards...
My System
Sony Bravia 46HX853 Calibrated Settings
