4 posts / 0 new
Last post
admin's picture
Last seen: 3 days 13 hours ago
sony str dh 820 amp
i have a new sony 820 amp and boston speaker system,i have set it up using the supplied mic and have the crossover at 120(boston recommendation)but i am getting siblance!Anyone with a solution?
f1only's picture
Last seen: 2 weeks 5 days ago
RE: sony str dh 820 amp
Is that through all speakers or just the subwoofer? how loud is it?
Another recommendation is after the initial setup, use an SPL meter ( use a tripod with it ) to check speaker levels using the test signal from the amp at your required sweet spot.
A/V Pioneer SCLX59 Speakers B&W 683 S2 685 S2 HTM61 S2 Centre 686 S2 For Atmos x4 ASW610 Sub x2 TV Calibrated 4K Panasonic TX-50AX802B BDP Sony PS3 & PS4 Pro HDMI Monster ISF2000HD Virgin Tivo Netgear ReadyNas104 12TB
Anonymous's picture
centre speaker only,may be the auto calibration,options are full flat,front reference and off,to get rid of it i have it at off but then the sound is "flabby"
f1only's picture
I've just had a quick read of the manual check page 93 about hums & noises, if you dont have the manual you can see / download the PDF version online Here
The auto callibration options shouldnt give it a hum effect after its completed & youve exited the function, so i would double check all the speaker connections are good.
Regards..
Log in to post comments
