Sky Sports graphics interfering with sub woofer?
Hi, new to this my first post, always been able to find what I wanted without asking
Problem
Had to replace my old Pioneer VSX-2016AV amp (new furniture TV cab to small) with a Pioneer VSX-S500
Finally got it all working but occasionally I have been getting strange noises from the sub woofer, rumbling popping sound, didn't know what it was, but whilst I was watching the live football on Sky sports it was happening quite a lot, then I noticed it was corresponding with the on screen graphics, the replay graphic, the pop up scores at the bottom of the screen, the video window when they are advertising forthcoming events etc.
Each particular graphic has its own sound very similar to each other, but the same every time.
Equipment
Sky 1T HD box
Samsung 46E8000 TV
Pioneer VSX-S500 AV Amp
Sony BDP460 Blu ray
Canton Cinema 5.1 Surround speakers including active subwoofer
Connections Sky direct to TV HDMI2, Sky to Amp Optical, Amp to Sub coax to low level input L, Amp to TV HDMI3 & Optical, BR to Amp HDMI
Help please
Thanks in advance
Thanks for replying, Yes, connected through a coax, should have mentioned it, I a spare Coax which looks sligtly better quality than the original which came with the speakers, I swapped, but exactly the same. no difference
You might try recording the offending football program. Then disconnect the satellite feeds from the back of the skybox and see if it still occurs when you then playback the recording.
Thanks again for taking time to reply
Tried the recording bit, sameas, then i played around with the line levels etc, I've got rid of the horrible noise it makes when the graphics are on, didn't realise they make a swooshing sound when they appear! haven't tried it with a movie yet to see if the sub volume is to low
- Login to post comments
I assume you're connecting the subwoofer low level input to the Pioneers pre-out(subwoofer) ?
Could be coaxial interference ?
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
