Shopuld I upsclae to 1080P at every stage or only once ?
My Blu ray player upscales to 1080P - My Denon AVR2808 Amp Upscales to 1080P and my Philips 46PFL9705 LED TV upscales to 1080P. Should I only upscale once ? or does it make no difference. If I should do it once, at which stage should this be done ?
Upscaling to 1080p will only be done once. If both your Blu-ray and your amp are set to upscale to 1080p, your Blu-ray player will do it as it's the first link in the chain - your amp and TV will not do anything. If you set the Blu-ray player to not upscale when playing DVDs, but your amp is set to upscale to 1080p, then it will then do this. Again, your TV will not do anything in this instance, just display the signal it receives. Finally, if neither the Blu-ray nor the amp are set to upscale, then the TV will upscale the image to fit its native resolution - assuming it's a Full HD set, this will be 1080p.
As Lee H noted, there's no rule as to which is best, it depends on your equipment. The best is to try switching off the Blu-ray upscaling (by setting the output to Original or 576p) and watch a DVD and see how the amp performs. Then switch off the amp's upscaling and see how it looks when the TV is doing it. Compare each and go with the one you prefer. Just remember, if you have to manually set your Blu-ray to 576p, you'll need to change it back to 1080p when watching Blu-rays!
Just the once will do very nicely. As to which one, I'd suggest trying both options: turn off scaling on the player, and the TV will do it, then try turning on the scaling on the player, and the TV will just take the signal ready-scaled, so to speak.
Bear in mind that the Denon doesn't, as far as I recall, do HDM-to-HDMI upscaling, so inputs on HDMI just pass straight through: it's only with analogue video inputs,such as component or composite video, that the amp's scaling is operational.
Isee if that is the case then Andrew I will leave the amp alone as all my video sources are connected by HDMI. Am I correct in thinking the SKY HD box attempts to upscale SD broadcasts ? If so is there anyway of turning this off ? or set it so it is only outputing a HD signal on an HD channel ?
CHeers
Yes, just set it to 'automatic' on the resolution option.
Use whichever one does it best. I find my AVR is better at it than my TV, so I let the AVR do it.
Formerly Still known as Lee H
