Setting Speaker Impedance
4 replies [Last post]
quad-gradientsetup
quad-gradientsetup's picture
Hi....,
Can someone tell me if you can change the impedance of individual speakers on the Yamaha RX-A1010 as my Fronts(Quads ESL63's with Gradient Subs) and Front Presence(Monitor Audio Bronze BX1's) are 8ohms, but my Centre and Surrounds(Monitor Audio Silver Centre and FX Surrounds) are 6ohms. I cant tell from the manual if you can....Please can somone clear this up for me...
Thanks in advance for your replies.....
RobinKidderminster
RobinKidderminster's picture
Online
RE: Setting Speaker Impedance
No you can't. Forget it / it will be fine. Impedance stated is only a guide since it depends on frequency. 4ohm may give a mismatch but yours are fine.
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1Base trap Project - http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-pro... treatment - click for pics : Room pix - Clicky : Old setup - Clicky
quad-gradientsetup
Hi. Thanks for that..
So is it best to just leave it at its default setting of 8ohms. Or should I set the impedance at 6ohms...?
Thanks…
Son_of_SJ
Son_of_SJ's picture
Online
Because you are using a mixture of nominally 8-ohm and nominally 6-ohm loudspeakers, you will need to set the speaker impedance on your Yamaha RX-A1010 to six ohms.
quad-gradientsetup
Thanks for thanks for clearing that up for me.…
