question for andy clough and musicraft
could you give me more explication on the sort of amplification i read
a amplification
d amplification and A/B amplification
second what do you think suit best music first i am a owner of a 5.1 r series keff
arcam 400 pioneer 86 and elite 68 sherwood newcastle yahama nad onkyo
i am thinking off changing my rotel for more upp too dates features
i know that anthem is also very good but not the easy way too configurate
and i am not so technically
My guess is...(though could be wrong)
Could you give me more explanation on the sort of amplification I hear about:
a amplification, d amplification and A/B amplification (ie. two different types of amplifier that I can switch between), or perhaps what are the differences between the two...(oh dear starting to lose it now
Secondly, which of the following is best for music, given that I have a 5.1 r series Kef :
- Arcam 400- Pioneer 86 and elite 68- sherwood- newcastle- yahama- nad- onkyo
i am thinking off changing my Rotel for something with more up-to-date features.
i know that Anthem is also very good but not that easy to set up, and I'm not very technical.
There...simples!!
thank you Dandy Cobalt
because i don't practise english whriting much i know it is not always clear
but you translated it perfectly
so yes what type off amplification suited best for stereo ????
i hear much good about maranz and nad but the mass brands like pioneer and onkyo are raving all the awards away
so i am a little bit scared that this is due to there anormous features ....
but for exemple the pioneer sl 86 is also known for his stereo
what do you two think about this ( dandycobalt and son_of_sj)
thanks for your reactions
No problem, though I'm not best qualified for the advice part. I understand that Yamaha is great is it's the music angle that you're taking. Though you can't go wrong with a high end Pioneer a/v receiver (sclx 86 is latest I think) and i recall that folk say it pairs well with Kef..
thank you and yes i am thinking about the pioneer lx 86
but i cann't demo him .......i am a little bit worried about brighness that is something that when you mentioned
pioneer most people are saying ...it is the same thing about marantz ...
otherwise yahama is known by uss for great home theatre but not for music (stereo) ...
nad and rotel excellent with music but lacking theatre functions ...
a amplification
Hi onlystyle
Which Rotel amplifier and KEF R Series speakers have you got please?
Is Anthem available to you locally from a shop based dealer?
All the best
Rick @ Musicraft
to musicraft
it is a 5.1 r keff system 2 frontspeakers are kef 300 back r100 central r200 subwoofer r400
i think i can procure an anthem
but i am a little bit afraid ....it likes that anthem set upp is really difficult
i am now running an rotel rx 1056.....he lacks the new features
also very intrest in
pioneer lx 86
nad 757 and uppwards t767 t777 and t787...
because my music is very very important even consideration for seperates
i read about marantz and rotel separates
Hi onlystyle
Thanks for your reply.
I used to sell Rotel's RSX-1056. Good amp.
Anyway, Anthem's MRX 700 AV reciver does an excellent job with movie and music soundtracks although i'll recommend that if possible in the first instance at least your dealer should set up the MRX 700 for you. Alternatively Yamaha's new Aventage RX-A3020 AV receiver and if budget allows Audiolab's new 8200AP AV processor/8200 x 7 multi channel power amplifier are also worth serious consideration. I think you'll find the Anthem, Yamaha and the Audiolab to offer a worthwhile upgrade over your Rotel RSX-1056. Other then the Anthem, Yamaha and the Audiolab i feel that you should also be on the right track with Arcam, NAD and Onkyo amplification.
Btw, i would avoid using bright/upfront and thin sounding amplification.
All the best
Rick @ Musicraft
thanks a lot musicraft ...i would come to your store if the distance was not so grate
living in Belgium that is a little to far
i am surely going to audition all brands you named .....favourites are nad and anthem
not that i am a extreme audiophil i adore analogue music and having more than 500 vinyls
you don't seem to be so found of the pioneer lx 86 ??? i saw that others matched them very well wit the keff r series ??? to bright???
ore is bright music tin ????
second on a belgium site "hificorner" they revied the new yahama series as being beast but not for audiphiles
last question i read many times about speakers and amplifiers been good for the american way of listen to music
and not for the british and all the way around . Could you expain this ??,
best regards
- Login to post comments
Hello there onlystyle,
I am neither Andy Clough nor Musicraft, but I must say that I find the English in your posting very hard to follow, in fact to the extent that I simply don't understand what you mean.
Click here to read about my system
