Please dont laugh!!
19 replies [Last post]
neverin
neverin's picture
Dont laugh but my home cinema set up comprises the following:
Mission 702e front speakers, Ditton centre speaker and 2 Mission 73 rear speakers powered by a sony DAV S550 with the sony std speaker cables due to the connections at the rear sony. The sony subwoofer is still connected! I also have a Sony BDP S373 Player a humax 9200T freeview recorder and an X box 360.
I have had the sony DAV S550 since new many moons ago and even though it was 5 stars at the time from what hifi i have always thought there was something lacking with it.
I have a new sony TV KDL 40-EX503 so i am looking for a suitable amplifier possibly Sony or Onkyo or what can you recommend?
The_Lhc
The_Lhc's picture
RE: Please dont laugh!!
HAHAHAHAHA!!!
Sorry, I mean, what's your budget?
__________________
No signature worth mentioning...
neverin
neverin's picture
Thanks for your sympathy!!!
I think about £500. Would i hear the benefit by spending more?
Big Aura
Big Aura's picture
your amp is definately the weakest link - I imagine it's really struggling to drive those speakers.  One think, assume your sub is the one that came with your sony DAV unit?  It will be a passive sub.  You'll need an active one to go with a new amp.  I'd look about for a 19** range, a Sony 8** range either discontinued lines (so bargains to be had) and possibly an ex-demo sub from a retailer (Sevenoaks have a large range of these - Subs don't tend to be run-ragged so much).
That should keep you within your price range.  Take a look on ebay too, you could get some secondhand gems for amps/subs there too.
EDIT- those are floorstanders?  Perhaps look at a Denon 2310/2311?
__________________
I have some home cinema and Sonos stuff.
The_Lhc
The_Lhc's picture
And, if you can manage it, try to find (secondhand probably) a centre speaker that matches your front speakers, having a centre from a different manufacturer is going to sound a little odd.
__________________
neverin
neverin's picture
Was the 19** range Denon? and the Sony the 800 or 810 or 820 models?
I see that wharfedale SUB150 has 5 stars would that go with most amps?
neverin
neverin's picture
Forgot to add, What about Onkyo amps?
Deliriumbassist
Deliriumbassist's picture
Onkyo 509 and a Wharfedale SW150 would be a good shout at the budget. The 609 is a step up, but that's your budget on the amp alone. I've always liked an Onkyo/Mission combo myself. Denon and Mission (well, MX range) is a bit too warm for my tastes.
f1only
f1only's picture
I would have to agree with most of the above posts, a Wharfdale SW150 active subwoofer is around £150 new or less, get a matching centre speaker to go with you other Mission 702e's off ebay for around £50 or so, leaving approxiamately £300 for an A/V amp. This would include end of lines AV Amps from last years models & a couple of this years, a small list of possibilities to research below for you, all available for £300 or less:-
Denon 2310
Pioneer 920
Onkyo 608 or 509 ( IMO i would go for the 608 if your choice ended between these two)
Yamaha 667 or 767
Sony 820
 Check out Richer Sounds, Sevenoaks, Superfi & others for end of line clearance bargains. This page on What HiFi has a good list of dealers to start off with Clicky
Regards ..
neverin
neverin's picture
I bought a mission centre speaker  so now all the speakers are Mission.
After playing a few blue rays i must say i think it all sounds really good.
I know that i am using an oid sony surround machine and sony standard speaker cable to power my missions and an old sony woofer but will spending money on a new amp and Smile Smile speaker cable and a new subwoofer really make that much difference?
Big Aura
Big Aura's picture
a new amp will make a huge difference.  your DAV unit was designed to run small speakers, and you've connected floorstanders to it.  Think trying to pull a 40 foot trailer with a rickshaw!  There are bargains out there.  I sold my old Denon 1909 on eBay for £150 last week - look for something similar (although for the size of your speakers I'd look for a more powerful amp - something like http://www.ebay.co.uk/itm/Denon-AVR-2310-7-channel-surround-receiver-ex-cond-/230697527496?pt=UK_AudioTVElectronics_Video_HomeCinemaSystems&hash=item35b6a4e8c8 (although I'm not vouching for the vendor).
__________________
bigboss
bigboss's picture
Online
You'll definitely hear an improvement with a better AV receiver & subwoofer. I can't comment on speaker cables as I have no personal experience.
__________________
markjaspi
markjaspi's picture
I agree the gains with something like this 2310 will be massive.
__________________
Panasonic 50GT30B | Marantz SR5006 | Boston Acoustics A26 front - A225C - A26 rear | Panasonic BDT310 | Sky+ 1TB HD | Virgin TiVo | iPad 2 | Samsung Galaxy SIII | New Apple TV | Control: Roomie via iPad & iPhone | Xbox360
Big Aura
Big Aura's picture
I'd be inclined to get an amp, and do without a sub (run as 5.Innocent until you're able to spend another 200 or so (as your Sony sub (being passive) won't work with an AV amp).  Speaker cables - get some £1 a metre copper ones from Richer Sounds.  Perhaps Cambridge Symphony 200 for fronts, and Cambridge Symphony 100 for rears.
__________________
Big Aura
Big Aura's picture
stupid emoticons - 5.0.
__________________
CnoEvil
CnoEvil's picture
Good advice given above. Change the amp first, followed by the Sub (check out BK). Finally use a good copper cable like Chord Carnival Silver Screen or Wireworld Stream 16/2
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
