pcm or bitstream
3 replies [Last post]
steakers
steakers's picture
whats the best setting out of these .
__________________
SONY  STR DH810 amp /SAMSUNG 40UE6100 3D TV "LED BACKLIT/ SONY STR810  amp /  x box 360/ .Panasonic DMP-BDT220 blu ray player/  Q Acoustics 2000i 5.1 speaker package.
professorhat
professorhat's picture
RE: pcm or bitstream
In theory, neither is better. PCM means the source decodes the audio i.e. from whatever compression has been used, usually Dolby TrueHD or DTS HD Master Audio. Bitstream means the native audio is sent to the AV receiver and it's decoded there.
Most people choose to use bitstream as it lights up your amp with the format that's in use (meaning it's easier to be sure you're getting HD audio on some of the older Blu-rays which defaulted to the Dolby Digital format). Some also claim that generally the sound is better this way round, whereas others will say it can't make a difference - I've not personally done any tests to confirm or refute that.
steakers
steakers's picture
thanks for that , ive had a bit of a mess about think the bit streams a little better , but see what you mean about the amp and its display.
__________________
The_Lhc
The_Lhc's picture
That's all that matters then, what YOU think sounds better.
__________________
No signature worth mentioning...
