pair of loudspeakers for yamaha rx-v673
7 replies [Last post]
Snkrishna
Snkrishna's picture
hi,
 I was thinking of hooking a pair of q acoustics 2050i or monitor audio rx6 to the yamaha rx-v673.
Any experience with this set up?
Thanks a lot,
krishna
MUSICRAFT
MUSICRAFT's picture
RE: pair of loudspeakers for yamaha rx-v673
Hi KrIshna
I've not heard Q Acoustics 2050i's with the RX-V673 however i can say that Monitor Audio's Silver RX6's form an excellent tonal match with Yamaha's RX-V673 Smile
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
David@FrankHarvey
David@FrankHarvey's picture
What you need to be careful of here is whether your 673 has adequate bass control for the speakers you're thinking of. If the receiver isn't up to the job, the speakers will lack punch, and bass will be ill defined resulting in a dull sound for both music and movies.
The RX6's aren't short of bass, and this usually requires a fair amount of control by the AV receiver. As good as the 673 is, if you want to be looking at £1,000 floorstanders, I would go for a more capable receiver like the RXA1020 or the outgoing RXA1010 if your budget is tight.
As well as the RX6 and 2050i, you could also look at the Tannoy DC6T (standar and special edition) and the KEF Q700.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
MUSICRAFT
MUSICRAFT's picture
Hi Krishna
If the system is to be used with two or five main speakers then the RX-V673 can configured to exert even greater drive and control over compatible speakers (such as Silver RX6's) by ultizing the suround back amplification to bi amplify the front main speakers. Please refer to the RX-V673's instruction manual ( page 21).
All the best
Rick @ Musicraft
__________________
Snkrishna
Snkrishna's picture
Hi David,
Thank you for your candid reply.
I had initially considered the marantz sr6007 but eventually settled for the v673 given the price.
Any opinion on the marantz?
cheers, krishna
Snkrishna
Snkrishna's picture
Hi Rick,
I guess that should work too. I will be initially only using two front speakers given budget restrictions. Perhaps consider adding some sorround stuff etc, sometime next year.
I am a novice at hifi,hopefully the suggestion you make is easy to implement.
regards, krishna
MUSICRAFT
MUSICRAFT's picture
Snkrishna wrote:
Hi Rick,
regards, krishna
Hi Krishna
Using the RX-V673 to bi amplify speakers is likely to result in an even clearer, tighter, faster and defined performance.
Btw, if you have any issues implementing bi amping then please ask.
All the best
Rick @ Musicraft
__________________
gurjitsidhu
gurjitsidhu's picture
i have the 673 amp and the 2050i speakers and they work very well together. they are very dynamic and punchy.
ive got the speakers bi-amped in parallel and found a big difference in sound quality over the traditional bi-amping. traditional sounded a it strained and the tweets and mids appeared very 'seperate' now they are good though!
i got the 673 with the 2050i since i will upgrade to the full q acoustics 2000 5.1 range but i wanted good stereo sound too. the bass from these speakers is very good and i dont need a sub.
overall, i would recommend the combo but the speakers take forever to run in!!!
__________________
Yamaha CDS300 CDP ----> Rega DAC-----> Yamaha AS500 Amp-----> B&W 684
Airport Express ------> Rega DAC-----etc..
