Onkyo TX-SR313 or Yamaha RX-V373??
HiLooking at both options but cant decide which. Also would I be better going with speakers packaged with amp from the same manufacturer or buying from different source i.e Tannoy SFX5.1? I already have a decent pair of Philips 5 x 100w speakers from a previous home cinema system. I was quite happy with quality from those so am curious to know would i see a massive jump in quality with the Tannoys or others in that price bracket? I am not an obsessive audiophile or anything and am limited to a budget of around 500 for amp and speakers or even cheaper if i can get away with old speakers. The system will primarily be used for 5.1 surround from blu ray source. Im not bothered about c.d/audio source playback etc. All suggestions welcome.Thanks
Hi
Thanks for your resposnse. yeah i was kinda veering towards the yamaha,cheaper and has the YPAO feature. i havent decided on speakers yet, im not that fussy anyway.thanks again
Any reason why you're only considering small satellite speakers? You could buid a nice set up out of Q Acoustic speakers which wouldn't break the bank and can produce a considerably bigger and better sound than the SFX5.1 without being too obtrusive.
ah just the salesperson from richersounds was recommendin the tannoys, i know he is a salesman though and everythin with a pich of salt!what model of speakers would you recommend from Q Acoustic?thanks
please be fussy because if you put your philips on this amp it will be like puting a cart wheel on a lorry.not good:rofl:
just checked richer sounds web site 373 and the wharfedale dx1 £429 wow thats cheep.go for it
haha sorry,im new to this game.havent a clue which is obvious. you reckon that package then?ill have a look.looks around my budget aswell. what do you suggest for a blu ray player?ive read an awful lot of bollix about these. from what ive researched picture quality is dictated by same chipset which comes from same factories regardless of make or model. more expensive models your just paying for extra gimmicks and features which i wont need anyway.
Or to simplify things you could get the Tannoy HTS101 package. Glowing reviews everywhere, even picked the best speaker package for up to £600 here on WHF and it's surely better than the SFX5.1 one. It's just over £300 on Amazon right now. It might not be as good as if you built your own package out of Q Acoustics 2020i and matching centre plus a sub but it's a cheaper and easier alternative.
thanks,decisions decisions!dont know which opnions to go with. as i said, im not an audiophile, anythin that is signifciantly better than an all in one home cinema kit(not settin bar high,i know) and isnt too expensive. i know silly money could be spent on these things if i had it
blu ray players are not the same.what size and what tv do you have
optoma hd230x projector
wow thats great.i think you mite need and good player.i hope that you have a 90" screen;) the pioneer bdp-450 should do a fine job with your optoma but it is £200
haha i aint payin that im afraid, can you please explain how that price is worth it? it outputs 1080p/24 just like most cheaper ones. what exactly is the difference?thanks.as ive stated im quite happy with a barebones player with zero extras/features/gimmicks
the pioneer has no extars or gimmicks as you said all it does is 1080p 24f but my god it does this very well.i have the denon 2012 which was £800 new and the picture on this is just amazing.my mate has the pioneer and its not far out from my denon thats a bargin.with your optoma it would be just jaw droping.movie night will never be the same again
sony bdvn590 this mite be what your looking for. thats a blu ray player and speakers for £320
- Login to post comments
hi there.the 373 is amazing for the price i have one.they are £200 and the tannoys are ok but for your budget you can aford the tannoy hts101s which are alot better.or wharedale dx1 hcp.these will be a massive jump quality.go to richer sounds
