11 posts / 0 new
Last post
Govian's picture
Last seen: 3 years 2 months ago
Onkyo TX-NR626 Picture Problem
Hi, maybe a newbie question
I have a 8000 series Samsung TV that has a fantastic picture. I have just bought a new amp to compliment it however running high quality HDMI cables through it, the picture on the TV look subtly worse
Anything I could have setup or menu changed to cause this?
Any help appreciated
malthus80's picture
RE: Onkyo TX-NR626 Picture Problem
Hi there. Welcome to the forum. I have experienced the same problem with HDMI pass through on my 606. I must admit im quite surprised that they havent improved the hdmi circuitry over 4 generations of amps. I can tell you that this effect gets less with use although it has never quite dissapeared. It seems to affect the high frequency detail such as film grain and edges appear less defined. Is it the same with yours. It does get more subtle though. Sorry i cant offer a solution but your not alone.
Govian's picture
Thanks for the reply
So this is a bedding in thing? The amp is new and does show the exact symptoms you mention. In particular the visible grain that used to be crystal clear. I was not sure if it was a setting I changed (was going to do a factory reset) or I should return the amp as its that new.
Would be a shame to re-route the hdmi's back to the TV and output just the audio.
How long did it take for it to be acceptable? Not a question a new amp should need asking
Govian's picture
malthus80's picture
Hi again. It should take a good few weeks for it to get better. It also improves as the amp warms up. It has never completely gone away on my amp but i have got used to it. I have no choice as i need to run it through the amp to get hd soundtracks off bluray. If you have two outputs on your bluray player you could use one to amp to decode hd audio and use the other direct to the tv for picture thus avoiding the amp. My sony 350 only has one output so i dont have that option. Anyway best of luck with the running in and i hope it improves.
davidf's picture
Last seen: 30 min 30 sec ago
Check the picture settings in the Onkyo's menu.
the little audio company, birmingham
audioquest / audio technica / amphion / bluesound / chord co / cornered audio / elipson / golden ear / innuos / jbl / kef / moon / ophidian / primare / revel / svs
Tarxman's picture
Last seen: 2 years 9 months ago
+1
Check the settings on amp and make sure any additional processing is set to off.
Tarxman's picture
+1
Govian's picture
Just for info/update. Plugging in the amp knocked the TV picture out. Running a factory reset on the TV sorted the issue. Amp was not the real problem
Many thanks to thoses who provided help/suggestions
Tarxman's picture
One other thing Govian, I'd probably suggest going into the tv settings menu and switching the "Anynet CEC" to off. I don't know what it is about Samsung's HDMI tech, but that one has been a headache for years!
Govian's picture
Thanks for the tip. Will do
Log in to post comments
