Onkyo 5008 or pioneer Lx-83 with Monitor audio APEX??
Hello, I am pondering over the following. I allready bought monitor apex 5.1 and want to buy a receiver to drive them.
I can buy the following receivers for approx. 1800 EUR.
Onkyo TX-NR5008 or
Pioneer Lx-83
I listened to the ma apex being driven by onkyo 3008 which sounded great (in my ears). I never were in the position to listen to the pioneer in combination with MA apex.
The cons of the onkyo are them getting really hot while playing. The reviews however are all great.
The pioneer reviews are all great too and the pioneer is using the ICE tech from B&O staying relatively cool while playing.
Does the pioneer match with the MA apex tonally? I read they both are quite bright.
Love to hear everybodies thoughts.
Cheers.
Onkyo TX-NR5008 or
Pioneer Lx-83
Cheers.
Hi Magdat
I would not recommend using Apex speakers with the LX83. As good as the LX83 is however i don't feel its tonal presentation is a suitable match for the Apex speakers.
Amplification such as those from Yamaha, Denon and Onkyo have tonal qualities which match Apex speakers and therfore help avoid a cold presentation.
All the best
Rick @ Musicraft
dfg
Well, you are too late. Just ordered the LX-83 as that 1 fits the cabinet the receiver should be housed in. Onkyo is 43,5 cm and does not fit.
Hope I can tweak the sound to my liking.
- Login to post comments
My SC-LX73 sounds excellent with the Apex, very precise and not at all bright, the EQ takes care of that. I've not heard these speakers with an Onkyo for a while, but I preferred the pioneer. Also although it does not get anywhere near as hot as the 876 I used to have, it's not far off my previous AVR a yamaha 1067, so I would not say it runs cool.
Panasonic 50GT30B | Marantz SR5006 | Boston Acoustics A26 front - A225C - A26 rear | Panasonic BDT310 | Sky+ 1TB HD | Virgin TiVo | iPad 2 | Samsung Galaxy SIII | New Apple TV | Control: Roomie via iPad & iPhone | Xbox360
