Old School Set Up
1 reply [Last post]
old hornet
old hornet's picture
Hi all
I have a budget of about £700.
Looking to replace my Onyko tx-sr806 as i bought used and never had a new amp.
Running Mission M73 FRONTS
m72c Centre
M70 rear
only a 5.1 set up
The amps iam looking at are Pioneer vsx-lx53(on offer at £699 or do i look at Onkyo say the nr808.
The sound at the moment is awsome for movies.
Not interested in music through it,use it for SKY HD AND bLUE RAY,XBOX
EQUIPMENT IS SKY HD BOX
PIONEER BDP-51FD
SONY BDP-S790 BLUE RAY
SAMSUNG PS60E6500
XBOX
DENON DVD PLAYER
OR ARE THERE ANY OTHER AMPS OUT THERS AT BARGAIN PRICES?
Codex77
Codex77's picture
RE: Old School Set Up
You should be able to find the Yamaha RX-A2010 for roughly your budget.  It's a top class AV receiver/amp which has been discounted by almost 50% because the newer models have recently come out.  The new 2020 is essentially the same but with airplay and 4K built in.  As you probably won't need 4k for several years (& that's optimistic) and as you can still use apple products with the older models, it's not too much of a problem.
__________________
Sony Bravia KDL-46HX853 3D smart TV, Yamaha RX-A2010 AV receiver, Monitor Audio Silver RX6 floorstanders, Monitor Audio Silver RX Centre, Wharfedale Valdus 100 SE bookshelf speakers (surrounds), Sony BDP-S790 blu-ray player, Sony Playstation 3 (500Gb).
