OHM's in speaker system
12 replies [Last post]
FROGIT
FROGIT's picture
Hi all forum members, I own a Sony multi channel AV receiver (STR-DN1010) operating through a 8ohms speaker system, I am not impressed with the receiver, and thinking of purchasing something from the Onkyo range, but these operate through a 6ohms speaker systems. Does it mean I would have to exchange all my speakers to accomodate 6ohm's. ?
Going back to my Sony AV/Receiver, I am having trouble to set up the system, I use to have it working through a 7.1 speaker system, but after my front room alteration,I have to return to a 5.1 speaker system, since the change I am having difficulty to set my surround back speakers. I have attempted to set up via Auto &  I have attempted to set up manually, but no luck. I would be very grateful for any responses or advice ?
Awaiting your replies, thanking you kindly.
Regards :- FROGIT
RobinKidderminster
RobinKidderminster's picture
Online
RE: OHM's in speaker system
Ohms - ignore it completely. Other issues?? Why having no luck? Whats wrong?
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
nawty
nawty's picture
Ohms are a propertly of the speaker not the amp, the lower the ohms the more difficult the speakers are to drive.
So, for example a cheapy amp my only be able to drive 8 ohm speakers so with that amp you shouldn't use speakers below that rated impedence.
A more expensive amp may be able to cope with a load as low as 4 ohms, that doesn't mean it still can't drive 8 ohms speakers, as they are easier to drive.
iHarpzZ
iHarpzZ's picture
this is difficult to explain AND difficult for you to understand!
Ohms is just the rating of the speaker you have.
The lower the ohms the, the less "power" the amp needs to give the speaker, making it easier to drive the speaker
as the guy said above me is correct woohoo!
Now your set up all messed up?
if im correct just reset your amp back to factory settings, and start again, as you did before when you had your setup nicely done
i did this before it worked fine after
to reset you will need to just go into settings and find reset factory.
__________________
iHarpZz =)
FROGIT
FROGIT's picture
Hi iHarpzZ  Thanks for your reply, I did not think of re-setting to Factory Settings, I will attempt next week.
FROGIT
FROGIT's picture
FROGIT
FROGIT's picture
Hi RobinKidderminster thanks for the reply.
Regards :- FROGIT
Big Chris
Big Chris's picture
Don't want to teach you to suck eggs, but you're sure you're using the surround left and right channels now, and not the surround back channels?
__________________
Hi-Fi: Arcam A85, P85, CD192. B&W 602S3, PV1, Grado SR125, Atlas Titan, Hyper 2.0.
A/V: Sony KDL-V40A12U, BDP-S760, Humax Youview, Onkyo TX-SR875, B&W MT30 7.1, QED HDMI-P, S.A XT
FROGIT
FROGIT's picture
hI nawty, thanks for your respose.
Regards :- FROGIT
FROGIT
FROGIT's picture
Hi Big Chris, in answer to your comment, I checked that the speaker cables this afternoon & they seem to be in the right position as per manual, thanks for your interest.
Regards :- FROGIT
nawty
nawty's picture
Quite the opposite actually, the lower impedence means the amp needs to give much more current to achieve the same power output (V=IR), high current is difficult for amps to provide so low Ohm speakers are MORE difficult to drive than higher Ohm speakers.  If you follow it to it's logical conclusion, 0 Ohms = short circuit and no amp likes that!
Son_of_SJ
Son_of_SJ's picture
This is now correct, and can be endorsed in any basic physics or electronics book, such as those which I had to read on the way to my BEng degree in Electronics, not to menton my MSc in Digital Techniques. Power (P) = Voltage (V) * Current (I) and with V = I * Resistance (R), we get P = I*I*R, or P = V*V/R. So all other things being equal, using that last formula, if the speaker resistance R goes down, then the power P consumed by the speakers (which the amplfier must provide) goes up.
RobinKidderminster
Online
rolling on the floor laughing
__________________
