New AV machine to handle 3D??
3 replies [Last post]
Mainiac
Mainiac's picture
I have an old SONY DA1200ES and while i have no complaints with it, will I need to upgrade it should I get a new 3D SMART TV?
Cofnchtr
Cofnchtr's picture
RE: New AV machine to handle 3D??
Depending on other sources and ultimate goal, the receiver should be OK for TV use only?
More information required to make an informed decision...
Cheers,
Cofnchtr.
__________________
Panasonic TX-50GT30B | Pioneer VSX-LX53 | Pioneer BDP-LX54 | B&W M1 x 5 | REL Strata | SKY+HD 1TB | Harmony One Remote | Contentment.
Mainiac
Mainiac's picture
Hi thanks for replying, the 3D/smart tv will be mostly used with the Sky 3D channels and 3D blu-ray movies/games thru my PS3, both of which are HDMI'd to the AVR, so if that set up will still work with no problems to my sound, then happy days.
would this work ok?
AnotherJoe
AnotherJoe's picture
Your amp will work fine with sky3d, but not for 3d blu-ray via the ps3.
You would need either a new 3d compatible amp - or a standalone 3d bd player with dual hdmi or analog outs.
__________________
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
