29 posts / 0 new
Last post
gel
gel's picture
Last seen: 3 days 1 hour ago
My Amp Not Reading Dolby True HD!
Just been playing some Blu-rays but it is not working, any ideas?  Master audio and the rest are working.  The amp is a Pioneer Vsx-lx70!
Stop
gel
gel's picture
RE: My Amp Not Reading Dolby True HD!
Jase Fox had a problem didn't he with this amp?
Stop
gel
gel's picture
Any ideas?  Worse comes to worse I will swap with my Dad again!
Stop
gel
gel's picture
It just says Dolby Digital!
Stop
professorhat's picture
Last seen: 3 weeks 6 days ago
RE: It just says Dolby Digital!
Easy gel!
Is the Blu-ray definitely set to the Dolby TrueHD soundtrack? Some older ones defaulted to the Dolby Digital and you had to manually select the TrueHD version.
The owls are not what they seem...
gel
gel's picture
professorhat wrote:
Easy gel!
I can't believe this!  Yep, just put Bon Jovi in which is Dolby True HD by default and not working just says Dolby digital, how can that be?  Tried the Batman's originally and went into languages but would not work!
Jase Fox had another problem:
http://www.whathifi.com/forum/home-cinema/strange-clickingsnapping-sound-coming-from-my-speakers-on-certain-movies?page=1
Stop
BenLaw's picture
Last seen: 1 year 10 months ago
With an oppo I'd be using the blu ray player to decode anyway.
I am the danger.
gel
gel's picture
Why would you do that?
Stop
gel
gel's picture
It just reads PCM then.
Stop
gel
gel's picture
DTS, master audio, Dolby
DTS, master audio, Dolby digital all working.
Stop
BenLaw's picture
IF there are any differences in quality of which component decodes then I'd trust the oppo more. If not, you don't lose anything.
I am the danger.
That's correct if the Blu-ray player is decoding.
If the Blu-ray is setup correctly (i.e. check Secondary audio isn't enabled as this defaults the main soundtrack as I remember), then sounds like the amp is faulty I'm afraid.
gel
gel's picture
Just reads PCM and sounds quieter.
Stop
BenLaw's picture
Yes the AVR will read PCM but you will be getting the proper soundtrack, decoded by the oppo. And turn the volume up!
I am the danger.
gel
gel's picture
Yesterday I was messing around with 3D and did change some things, but I am pretty sure I am back to how I was.  One thing I can do is hook up my Pioneer Blu-ray player and see if that is working.  I will do that next.
Stop
gel
gel's picture
I don't like doing it that way.  Smile
Stop
Pages
Log in to post comments
