Marantz SR7005 Airplay problem using windows PC
Good morning,
Please note that I have the following two problems with my recent Marantz SR7005 Airplay update:
As soon as I did the update I noticed that when the receiver is in standby mode and I switch on my windows PC the receiver turns ON by its own and goes to NET/USB stage. Is there a possibility to stop this so that it will just turn ON automatically only when I open the iTune program and select the SR7005 speakers?
Also I noticed that when I use the iTunes program and select my computer speakers the program works fine but as soon as I select the SR7005's speakers the program works for three seconds (from the SR7005's speakers) and then stops on its own.
I removed the iTune software and installed it again but nothing has changed.
Any ideas.....?
Have a nice day,
Kind regards,
Chris
- Login to post comments
solved!!
go to SR7005 manual mode->network->others-> uncheck the hdmi standby mode
go to windows 7 settings and run a network adaptor repair session
