I have got a new Pioneer SC-LX85. And LOADS of questions!!!
6 replies [Last post]
umbucker
umbucker's picture
I got this for christmas, and due to haveing a home cinema system for several years, I was expecting this to be up and running within an hour or so. Boy was I wrong!! I admin most of the time was speant trying to get sky to work through Optical which I understand has been an issue with this model and is now resolved, however not on the 'sky' channel which is annoying.
Anyway I have gone as far as I can with it and was hoping someone could answer the following queries/problems I have
Firstly - The crossover settings, I cannot find anywhere through the menus here you can induvidually set the crossover for each speaker, I can set an overall crossover in speaker settings but surely there a way to do this on each channel ?
Similar to the last question, on my previous Denon model there was a way to set my front speakers to 'Large' while still having a set crossover to the sub woofer to have say below 60HZ running to the subwoofer while still having full range throught the fronts. Is there no way of doing this on the Pioneer ?
Finally is there a way of setting a particualr surround format for each input? eg, having sky set to DTS NEO X, but when switching to CD t will automatically switchto Stereo ?
THis will do for now Smile
Amadeus1756
Amadeus1756's picture
RE: I have got a new Pioneer SC-LX85. And LOADS of questions!!!
Sorry, can't answer any of your questions, but genuine (ignorant) question from me - why would you want to change the crossover settings per speaker?
thanks
__________________
Things will never be the same again
umbucker
umbucker's picture
Hi To answer your question I have floorstanders L+R which are considered full range but no way can reach the depths of my 12" sub. So I would like to set crosover to 50 Hz here. I have much smaller rears and centre so a crossover at around 80Hz would be better here. I could do this on my Denon AVR2808 but there is only one crosover on the Pioneer....
The_Lhc
The_Lhc's picture
have you run the auto-calibration on the LX-85? I understand it's quite extensive, I'd be surprised if it doesn't do all the things you require.
__________________
No signature worth mentioning...
umbucker
umbucker's picture
I have done a full Auto set up but the results only show a single crossover at 50Hz
michael hoy
michael hoy's picture
I have a 85 and I belive you cannot set the crossover per speaker.
Not sure what you mean by "however not on the 'sky' channel"
__________________
AV System -  Panasonic 42VT30 ¦ MA Apex 5.1- 4xA10 1xA40+ AW-12 Sub ¦ Van Damme UP LCOFC Speaker Cable ¦ Pioneer SC-LX85 ¦ OPPO 95 ¦ Mark Grant G1500HD Precision audio cable ¦ Sky+ HD(1TB) ¦ Chord Active HDMI ¦ Belkin PF50 mains conditioner.
Bedroom - Sony KDL-40W2000 + Archos 7 streaming from Windows Home Server 2011, Altec Lansing inAir 5000.
Dining Room - Sonos S5.
Music - HP Proliant Server running WHS 2011 ¦ streaming FLAC to Sonos ZP90 and OPPO 95 via SC-LX85.
Hi Fi - Cyrus 8 XPd QX amp ¦ Cyrus PSX-R power supply acting as Pre Amp ¦ Quad 909 Power Amp ¦ Speakers - Spendor A3 ¦ Logitech Squeezebox Touch upgrade by Fidelity Audio ¦ power supply upgrade by Mains Cables R Us ¦ Power Plant Premier mains regenerator.
Controlled by – iPad2 and Harmony 1100.
Amadeus1756
Thanks Umbucker.  I never expected it to be so complicated.  I've so much to learn.
__________________
