how to match lenght of wires of each channels
6 replies [Last post]
dr.shah.deepan
dr.shah.deepan's picture
i have kept shortest each length of wire for each pair of speakers i.e. frnt lt-rt equal shortest possible lenght, surr. lt-rt equal shortest possible length , and surr. back lt-rt equal length and avery short wire for centre. this gives me equal wire length for each pair but different lengths for each set of channels is it rt way to connect??? plz help.
Paul.
Paul.'s picture
RE: how to match lenght of wires of each channels
I wouldnt worry, cable length doesn't make an audible diference.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
tino
tino's picture
__________________
Squeezebox Touch | Wadia 151 | Aliante Moda PF
dr.shah.deepan
thnx tino
thnx tino that link is useful i will have to give some time to first understand properly and then apply on my system.
dr.shah.deepan
hi paul actually its my psycological problem that i want everything as per book even though its practically not that audible hahaha... i cant help myself!!!
ellisdj
ellisdj's picture
If you are being anal about it - I would have the eaxct same distance of wire for my front 3 or very close.
So the same length cable for Front L, Front R and Centre Wink
__________________
Meridian G61R, HD621, G55, MC200, MS600
Panasonic 65VT65, Marantz UD7007, HIFi Racks Podium Reference
Monitor Audio GX100, GXC150, Apex A10, BK XLS400 (set with hard knee house curve)
Graham Slee Spatia (SC) Graham Slee Cusat 50 (IC x 5 Analogue,x 4 Digital)
chudleighpaul
chudleighpaul's picture
Are you having a laugh?
